2006RX400h Posted April 8, 2009 Share Posted April 8, 2009 My 2006 400h does not automatically unlocks the door when I put the gear in 'P' position or pull out the key from the ignition. I tried set it by following the manual's instruction but couldn't. Does any of you have same prob.? Any solution? or Should I need to take my to dealer? Thanks. Quote Link to comment Share on other sites More sharing options...
pauljcl Posted April 8, 2009 Share Posted April 8, 2009 My 2006 400h does not automatically unlocks the door when I put the gear in 'P' position or pull out the key from the ignition. I tried set it by following the manual's instruction but couldn't. Does any of you have same prob.? Any solution? or Should I need to take my to dealer? Thanks. In my 2009RX350, this is set by the dealer as part of the various 'settings' you can choose. The 'lock doors when in D' and 'unlock doors when in P' seems to be the default. Quote Link to comment Share on other sites More sharing options...
SOMEONE ELSE'S GOT MY NAME Posted April 8, 2009 Share Posted April 8, 2009 Althouth the Dealer is not under any obligation to do (or make) changes on your settings if you bought your car used, our dealer did them for us twice. The last time was when our auxiliary battery died (2 weeks ago) under warranty. Maybe that was why they went and did it ... who know ... but they reset the sunroof, DVD map settings, windows & door locks. Quote Link to comment Share on other sites More sharing options...
katzjamr Posted April 8, 2009 Share Posted April 8, 2009 i have had the dealer reset things a couple times and as long as i ask them while it is there for another service they have always done it no charge. Quote Link to comment Share on other sites More sharing options...
RX400h Posted April 8, 2009 Share Posted April 8, 2009 I still can't figure out why Lexus hadn't built in an owner-changeable capability. My Corvette allows me to not only change any of many settings such as door locking, seat movement rearward upon entry, and twilight lighting functions, but it also allows me to extract fault codes (very necessary when you have a GM product) and reset them with a push of a button. Quote Link to comment Share on other sites More sharing options...
LexRexBlue Posted April 9, 2009 Share Posted April 9, 2009 It's one of those personal settings. There are many different ones. You might want to look and decide on all the ones you want and then ask the dealer. Even though it is used, most dealers want you for service so they should as a courtesy do it for you free. Mine is always happy to make changes. Quote Link to comment Share on other sites More sharing options...
pauljcl Posted April 9, 2009 Share Posted April 9, 2009 I still can't figure out why Lexus hadn't built in an owner-changeable capability. My Corvette allows me to not only change any of many settings such as door locking, seat movement rearward upon entry, and twilight lighting functions, but it also allows me to extract fault codes (very necessary when you have a GM product) and reset them with a push of a button. Yes, I'm with you there. I believe Lexus should have included the ability to change many of the settings by 'code' for the owner via some of the buttons such as the info. buttons. I do not have experience with many other car-makers, but unfortunately BMW has the same approach: any change of settings must be done by the dealer (and here in Miami Braman Motors - which I highly recommend avoiding - wants to charge $60 per change of settings EVEN ON A NEW CAR!!). So, in a way, Lexus dealers are kind to offer change at no cost. But not all changes are available: for instance, I would like to 'delete' the automatic re-setting of the avge. fuel consumption whenever you refill the gas tank. The old RX300 had a continuous 'avge' irrespective of refills, and that made a lot more sense, particularly since you can 'reset' the counter/computer whenever you want. Quote Link to comment Share on other sites More sharing options...
RX400h Posted April 9, 2009 Share Posted April 9, 2009 That would certainly be handy in a hybrid vehicle. Quote Link to comment Share on other sites More sharing options...
Better Luck Posted April 22, 2009 Share Posted April 22, 2009 That would certainly be handy in a hybrid vehicle. Funny you should mention that, my Prius was reset automatically everytime I refilled the tank. Is the resetting of the personal settings done with some special equipment or is there a secret handshake way of doing it? Where are the Lexus techs. on here? They must have insight to this. Quote Link to comment Share on other sites More sharing options...
vinovelo Posted April 23, 2009 Share Posted April 23, 2009 I still can't figure out why Lexus hadn't built in an owner-changeable capability. My Corvette allows me to not only change any of many settings such as door locking, seat movement rearward upon entry, and twilight lighting functions, but it also allows me to extract fault codes (very necessary when you have a GM product) and reset them with a push of a button. Yes, I'm with you there. I believe Lexus should have included the ability to change many of the settings by 'code' for the owner via some of the buttons such as the info. buttons. I do not have experience with many other car-makers, but unfortunately BMW has the same approach: any change of settings must be done by the dealer (and here in Miami Braman Motors - which I highly recommend avoiding - wants to charge $60 per change of settings EVEN ON A NEW CAR!!). So, in a way, Lexus dealers are kind to offer change at no cost. But not all changes are available: for instance, I would like to 'delete' the automatic re-setting of the avge. fuel consumption whenever you refill the gas tank. The old RX300 had a continuous 'avge' irrespective of refills, and that made a lot more sense, particularly since you can 'reset' the counter/computer whenever you want. This confuses me. My 2008 RX400h does not do this at all. I have to manually clear the mileage every time I fill up. One thing that drives me nuts personally is that the doors do not auto lock if I forget to lock them. All of my other cars both with OEM and after market systems do this as default. There have been a few times I have been shocked to find out the next day that my vehicle has been unlocked all night. Here is a scenario. Shopping, hatch filled up. Exit vehicle. Open hatch, close doors. Unload hatch area. Carrying in last load of groceries, close the rear hatch with the remote. vehicle doors are now left unlocked (as I forgot to hit the lock button after the hatch close button). This drives me NUTS! /Steve Quote Link to comment Share on other sites More sharing options...
Gryphon Posted April 23, 2009 Share Posted April 23, 2009 Steve, that is an option that can be changed by your dealer. Tom Quote Link to comment Share on other sites More sharing options...
mowmow Posted April 25, 2009 Share Posted April 25, 2009 Lexus has a service call "Personalize Settings" where they will program the car the way you want it. I was able to program the car to lock doors when my RX400h goes over 10mph, and this is just following the owner's manual instructions. Quote Link to comment Share on other sites More sharing options...
vinovelo Posted April 25, 2009 Share Posted April 25, 2009 Steve, that is an option that can be changed by your dealer.Tom FWIW, I did not see this listed on the personalized settings sheet. But, I notice the sheet had a 2006 date. Was this added as a setting recently (i.e. 2007-2008 models)? /Steve Lexus_Personalized_Settings.pdf Quote Link to comment Share on other sites More sharing options...
katzjamr Posted April 25, 2009 Share Posted April 25, 2009 i remember making them turn it off, i dont like having everything lock up and unlock all day long, i am in and out of the car frequently so it must be there somewhere. Quote Link to comment Share on other sites More sharing options...
Gryphon Posted April 25, 2009 Share Posted April 25, 2009 My apology, I misread your post Steve. I don't think that there is a setting to change that behavior. My rear hatch is unlocked after opening/closing too, which I find a bit ridiculous on a $50K vehicle. Tom Quote Link to comment Share on other sites More sharing options...
