The Kid Posted February 25, 2009 Share Posted February 25, 2009 Hey I went on a nice run, maybe 80 or so miles and I set the car to 80 mph cruising. and the temp gauge got down to nearly C is this normal? I asked my mechanic and he said that isnt a problem. cars run better when they are cooler and more air is flowing through the engine. he said it would only be a problem when the gauge gets closer to H so... is this true? or does my car really have a problem like I suspected? Quote Link to comment Share on other sites More sharing options...
jonjdurkin Posted February 25, 2009 Share Posted February 25, 2009 What was the air temp at the time?-mine does the same when the temp is below 40-and when coasting downhill. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted February 25, 2009 Share Posted February 25, 2009 Hey I went on a nice run, maybe 80 or so miles and I set the car to 80 mph cruising. and the temp gauge got down to nearly C is this normal? I asked my mechanic and he said that isnt a problem. cars run better when they are cooler and more air is flowing through the engine. he said it would only be a problem when the gauge gets closer to H so... is this true? or does my car really have a problem like I suspected? Check your thermostat. Quote Link to comment Share on other sites More sharing options...
Threadcutter Posted February 25, 2009 Share Posted February 25, 2009 Hey I went on a nice run, maybe 80 or so miles and I set the car to 80 mph cruising. and the temp gauge got down to nearly C is this normal? I asked my mechanic and he said that isnt a problem. cars run better when they are cooler and more air is flowing through the engine. he said it would only be a problem when the gauge gets closer to H so... is this true? or does my car really have a problem like I suspected? Replace your thermostat......... (edit) Replace your radiator cap too...... Quote Link to comment Share on other sites More sharing options...
The Kid Posted February 25, 2009 Author Share Posted February 25, 2009 the outside temp was maybe about between 25- 30 degrees and cruising at 80 OHHHH YEAH and by the way, the low coolant light came on too and I had to pull over and put some in there because it got bone dry. so after i put that in there, i thought it would solve the problem, but the temp gauge still dropped pretty low when I started back driving. i didnt cruise at 80 any more though, more like 65 Quote Link to comment Share on other sites More sharing options...
Budhah Posted February 25, 2009 Share Posted February 25, 2009 the outside temp was maybe about between 25- 30 degreesand cruising at 80 OHHHH YEAH and by the way, the low coolant light came on too and I had to pull over and put some in there because it got bone dry. so after i put that in there, i thought it would solve the problem, but the temp gauge still dropped pretty low when I started back driving. i didnt cruise at 80 any more though, more like 65 Could have air in the lines. Just adding coolant does not mean that the pump is pumping water. When you removed the cap, did you get a whoosh?? Seems you just might have a hose or radiator leak. and if pressure not on the system funny things can happen. Could just be a Rad Cap too.. Quote Link to comment Share on other sites More sharing options...
amcdonal86 Posted February 25, 2009 Share Posted February 25, 2009 the outside temp was maybe about between 25- 30 degreesand cruising at 80 OHHHH YEAH and by the way, the low coolant light came on too and I had to pull over and put some in there because it got bone dry. so after i put that in there, i thought it would solve the problem, but the temp gauge still dropped pretty low when I started back driving. i didnt cruise at 80 any more though, more like 65 Wouldn't you think the two problems were related? :P Coolant should never be consumed. You must have a leak in your cooling system somewhere. Check your hoses and radiator! I may be wrong, but I believe the temp gauge is for coolant temperature. If your coolant is bone dry, it would probably just show the temperature as being lower, when in fact, your engine is probably overheating. Quote Link to comment Share on other sites More sharing options...
17LexusOwner Posted March 3, 2009 Share Posted March 3, 2009 I've been having the same problem. My coolant level is fine though and I also recently replaced the cap. But my temp gauge always reads very low and my car has a hard time heating the cabin during the winter months. I have a picture of what my gauge is at after awhile driving. Thermostat stuck open? Quote Link to comment Share on other sites More sharing options...
17LexusOwner Posted March 6, 2009 Share Posted March 6, 2009 yes/no? Quote Link to comment Share on other sites More sharing options...
NewGuy19 Posted March 6, 2009 Share Posted March 6, 2009 A lower operating temperature is good to have, but that looks like something definitely isn't work properly. The only time my gauge has read that cool was on a trip home this winter while I was cruising along at 75 and it was -25 outside. Quote Link to comment Share on other sites More sharing options...
17LexusOwner Posted March 8, 2009 Share Posted March 8, 2009 Yea i thought as much. It's like that all the time. Highest it goes is a little above the first tick. What is it normally sposed to read? Cause i just bought a different lexus of the same year and it hovers around 75% I'm gonna order up a thermostat and replace it. Hopefully that fixes it. Quote Link to comment Share on other sites More sharing options...
python Posted March 8, 2009 Share Posted March 8, 2009 lower temps are not good to have, ur sensors run off the temp of the motor....u have stuck thermostat Quote Link to comment Share on other sites More sharing options...
