Cel Po401
jerzyjim
I went to AutoZone this morning and they read my CEL code. It was PO401 and the definition was too little flow on the EGR system and follows;
1. Blocked passage on EGR system.
2. Failed EGR valve.
3. Failed EGR pressure sensor where applicable.
4. " " position " " " ......
Has anyone run into this problem, ( the car runs great and MPG are great ),and if so , any suggestions ? Has anyone used Seafoam in the intake and would this possibly take care of this problem.
thanx for any help,
jerzyjim
I had the same problem on my car.
I cleaned the EGR valve itself and changed the EGR temperature sensor. Neither fixed the problem.
Finally when I needed a new head gasket I had the head cleaned and a valve job done.
Once I did this work, no more problem. I assume the passages were partially plugged.
Tom
Check your egr vacumm modulator filter. See if that fixes your cel. Here's the HTD:
http://www.lexls.com/tutorials/emission/egrfilter.html
Mr. Motorhead,
thank you very much for the info. My engine doesn't look like that; ('97 sc300 I6 cyl )
thanx again,
jerzyjim
Now you tell us! Why didn't you put that in your original post? You should update your profile info.
