lovlex Posted December 23, 2003 Posted December 23, 2003 my 1992 sc 400 calls for 91 octane. wher i live, we have 89 and 93 but no 91. should i use the 93 or is the 89 okay? will it make that much of a difference? thanks.
UCF3 Posted December 23, 2003 Posted December 23, 2003 You can use either. It won't do any damages. I personally put 93 because it's a cleaner burning fuel.
K9crew Posted December 23, 2003 Posted December 23, 2003 Why not fill up your tank with both ... half 89 and half 93?!! You'll save some money that way. :) You don't want to put in straight 89 though since with these high compression engines you could do some damage when/if the fuel pre-ignites. :)
K9crew Posted December 23, 2003 Posted December 23, 2003 My '95 and '99 400's have compression ratios in excess of 10:1 so you may want to stay away from "neat" 89!! :)
southernsc300 Posted December 23, 2003 Posted December 23, 2003 what state you live in? i know down here in Texas there is no 91 octane unless you go to a shamrock i think, i know every 7-11 i have been to has 91 octane
tinman Posted December 28, 2003 Posted December 28, 2003 If you live in the Midwest, go higher, especially in the winter months. We get reformulated gas here that is a little off in the octane rating when it's actually put in your motor. The SC does have 2 knock sensors and they seem to keep a good eye on things and the ECU learns pretty fast about what it can and cannot do with timing and fuel control... But, if simply for the sake of keeping the power up, I'd personally go with a higher octane with a high compression motor like the 2JZ. Look at it this way: You cannot go wrong with 93.
tinman Posted December 28, 2003 Posted December 28, 2003 If you live in the Midwest, go higher, especially in the winter months. We get reformulated gas here that is a little off in the octane rating when it's actually put in your motor. The SC does have 2 knock sensors and they seem to keep a good eye on things and the ECU learns pretty fast about what it can and cannot do with timing and fuel control... But, if simply for the sake of keeping the power up, I'd personally go with a higher octane with a high compression motor like the 2JZ. Look at it this way: You cannot go wrong with 93. err make that a 1UZ motor. The SC300 has a 2JZ :D
UCF3 Posted December 28, 2003 Posted December 28, 2003 I would say the 2JZ is also a High Compression Ratio Engine, don't you think? Lovlex: You have another option if you're interested in getting 87. Add a bottle Octane Boost--6 or 7 will work--to get the 93 level you need. Here's the catch, you'd have to add a bottle of Octane Boost every time you empty your tank. Since the cost of Octane Boost around $4-10 and the price of 87 grade fuel, you might end up paying the same amount as 93 grade fuel.
xoom04 Posted December 28, 2003 Posted December 28, 2003 i have always used 93 for my 1993 sc400. the engin is still running quiet and strong at 112,379 miles. i occationally add a bottle of octane boost on top of the 93 gas in the winter for a little fun :D . also, its a good idea to add fuel injector cleaner every time u get ur oil chnaged.
joedoc Posted January 2, 2004 Posted January 2, 2004 Which injector cleaner? I have used Chevron techron, but are there significant differences?
UCF3 Posted January 2, 2004 Posted January 2, 2004 Which injector cleaner? I have used Chevron techron, but are there significant differences? You can clean you injector cleaner anytime. It doesn't go in with your oil. I've heard Mobil has detergents in its fuel. Same with Chevron. For some funny reason, Hess has really good fuel. My car feels a lot better, and runs faster <_<
BlackSC4 Posted January 2, 2004 Posted January 2, 2004 how about 76 pro power? i like to keep my fuel consistent, and theres plenty of 76's around to easily do that.
UCF3 Posted January 2, 2004 Posted January 2, 2004 how about 76 pro power? i like to keep my fuel consistent, and theres plenty of 76's around to easily do that. Don't know about 76. Unfortunately I live on the East Coast, where 76 gas stations aren't available. Have you checked out their Website?
xoom04 Posted January 2, 2004 Posted January 2, 2004 i use the stp fuel injector cleaner....and i know u dont have to put it in w/an oil change, but its a good idea to make it the time to do it so u dont forget and get it done on a reg basis. its not something u need to do all the time unless u burn vegetable oil :D
