trevordbs Posted September 1, 2008 Share Posted September 1, 2008 speedodometer stopped working properly, how much does that usually coast? the button, PWR ECT, what does that exactly do? i looked through the manual and didnt anything on the same kind i have. thankyou. Quote Link to comment Share on other sites More sharing options...
killerFatty Posted September 2, 2008 Share Posted September 2, 2008 the ect pwr button makes the ecu make the fuel/air ratio richer Quote Link to comment Share on other sites More sharing options...
steve2006 Posted September 2, 2008 Share Posted September 2, 2008 The ECT power switch allows the engine to reach higher RPM before the gear changes up so it's like a sports mode and on some models the suspension is also stiffened. As for the speedo check the wiring to the speed sensor on the transmission 1st. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted September 2, 2008 Share Posted September 2, 2008 It is in your manual. Read it again carefully. The ECT (Electrical Control) is a switch that gives you control over the tranny's shift pattern. As Steve correctly explains, the Power mode raises the shift points on the tranny, which raises the rpm, getting you further into the power band of the engine for better acceleration. Quote Link to comment Share on other sites More sharing options...
