HankJ Posted July 19, 2008 Share Posted July 19, 2008 Hi, What is the best way to clean and lub the door and window seals? The seals "pop" when I lower them if they haven't been used for awhile. Also, I'm starting to get wind noise, at time, from my driver window, not all of the time, but sometimes. Thanks, Hank Quote Link to comment Share on other sites More sharing options...
JENunnez Posted July 19, 2008 Share Posted July 19, 2008 Go to Detailing section there's plenty of info there. Quote Link to comment Share on other sites More sharing options...
HankJ Posted July 19, 2008 Author Share Posted July 19, 2008 Go to Detailing section there's plenty of info there. and the 'detailing' section is where? Quote Link to comment Share on other sites More sharing options...
JENunnez Posted July 20, 2008 Share Posted July 20, 2008 Ok here you go, 303 Aerospace Protectant , best you can buy(In my opinion). Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted July 20, 2008 Share Posted July 20, 2008 Go to Detailing section there's plenty of info there. and the 'detailing' section is where? The detailing section is on the main forum page. Here is a direct link: http://www.clublexus.com/forums/forumdisplay.php?f=122 Quote Link to comment Share on other sites More sharing options...
HankJ Posted July 20, 2008 Author Share Posted July 20, 2008 Where can I buy the 303? Thanks, Hank Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted July 20, 2008 Share Posted July 20, 2008 i usually just use silicone spray... Quote Link to comment Share on other sites More sharing options...
HankJ Posted July 20, 2008 Author Share Posted July 20, 2008 Is that better than WD40? Quote Link to comment Share on other sites More sharing options...
dfkd Posted July 21, 2008 Share Posted July 21, 2008 Completely different stuff. WD40 may actually damage the rubber. Silicone lube is cheap (around $5) and one can will last you a long long time. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted July 21, 2008 Share Posted July 21, 2008 Where can I buy the 303?Thanks, Hank Napa or Kragen Auto Parts. Quote Link to comment Share on other sites More sharing options...
JENunnez Posted July 21, 2008 Share Posted July 21, 2008 Any good marine supply should have it. Don't use any oil based lubricants because it will damage the seals. If you can't get any you can use ArmorAll. Quote Link to comment Share on other sites More sharing options...
