Latoilette Posted December 3, 2003 Share Posted December 3, 2003 it all worked fine until i put Phillips 9006 HID kit. after the install... right side works good, left side blinks fast. when i use emergency hazard light, both side comes on perfect.. I've checked the bulb and bulb was fine...but anyways..i'd changed the bulb to a new one. problem still exist. only when i give left signal, it blinks FAST. any word of wisdom would be appreciated. Quote Link to comment Share on other sites More sharing options...
cui Posted December 4, 2003 Share Posted December 4, 2003 does the "rear light" light comes on in the dash? My right side is blinking faster only if I step on the brake...and I know I have burned out light bulbs... just never get to replace them...and my "rear llight" is on in the dash.... check to make sure all bulbs are okay...normal and when brake is on... Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 4, 2003 Author Share Posted December 4, 2003 rear lights work without any problems. i am stunned...this has never happened before. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 4, 2003 Share Posted December 4, 2003 The "rear light out" is not associated to the turn signal cuircit. You may have damaged a wire changing out the wires. Or there could be a wiring problem cuasing a bad ground which is reversing the flow of the cuicit of the signal. Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 5, 2003 Author Share Posted December 5, 2003 but why just one side? not both sides.. if the ground was bad, it should affect both sides..right? i've pulled the headlight out today, looked at the whole thing...everything's in good shape. i couldn't find the ground point for the headlights though.. (it must be connected to other wires and share a common ground point) Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 5, 2003 Share Posted December 5, 2003 you will only be able to know by tracing it back throught the wires. Have you reinstalled the old lights to see if it stopped. Each side signal is on its own cuicit the hazard just runs on it own relay. Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 5, 2003 Author Share Posted December 5, 2003 i will try the old lights tomorrow. thanks for your help so far. i really do appreciate your patience and time. Quote Link to comment Share on other sites More sharing options...
Roman Posted December 7, 2003 Share Posted December 7, 2003 My right blinker goes fast too, but only when the lights are on? How do you take the headlight out to change the bulb? I had all the screws I can see out, but still no luck. What is the trick? Thanks Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 7, 2003 Author Share Posted December 7, 2003 popping out the headlight was easy. disconnect all those little things behind it..9006, 9005 and that blinker one. pull that plastic cover (3-4 screws and a plastic pop up) undo 2 bolts (toward the center of the car, where the grille is) pull the whole thing out. my problem exist wheather lights are on OR off. Quote Link to comment Share on other sites More sharing options...
Roman Posted December 7, 2003 Share Posted December 7, 2003 I have an ES300 mnfg. 11/95 and it has three screws. Even after removing all of them the light will not move. It is a one piece light and it seems to have a screw inside than can be remooved only after taking the front lens out, but that is not easily obvious to accomplish either. I am waiting for a Haynes manual and hoping for instruction there. Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 7, 2003 Author Share Posted December 7, 2003 interesting. let me know when you find out. there were only 2 things that held the headlights on my car. someone probably tempered it before me..i guess. when you find out, share the valuable info with us. Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 9, 2003 Author Share Posted December 9, 2003 Okay..last night, i put back the right original 9006 bulb. blinker problem still exist. i checked every single bulb..including all interior ones..they are fine. all fuses, relays are fine too. right signal clicks at normal rate, left signal clicks faster if i press the hazard light..both light blinks at normal rate. Does anyone have this kind of problem on their es300? Personally, i bought a lexus to avoid little problems like this, but so far, lexus is not being nice to me. Quote Link to comment Share on other sites More sharing options...
doiturself Posted December 9, 2003 Share Posted December 9, 2003 Just replace a new bulb where it's problem, but you have the right one. There are 2 terminals on this bulb if one of the terminal goes out then the bulb will blink must faster than it should be. If you look close, you will see there 2 terminals on it's bulb. Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 10, 2003 Author Share Posted December 10, 2003 thanks. i will do that tomorrow. Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 11, 2003 Author Share Posted December 11, 2003 i just replaced it with the brand new one. problem still exists...help? Quote Link to comment Share on other sites More sharing options...
doiturself Posted December 11, 2003 Share Posted December 11, 2003 If you replaced all old light back and still have same problem then there is one of the light is broken. The blinking has to do with one of the terminal is out, so check all your signal lights. You can also try to leave one bulb missing and see how the signal light reacts. Quote Link to comment Share on other sites More sharing options...
bbsal Posted December 11, 2003 Share Posted December 11, 2003 check the contacts on the light housing.i had the same problem and fixed it by rubbing the contacts with some sand paper and that fixed it.if you replaced the bulb then its the contcts on the light not the bulb. Quote Link to comment Share on other sites More sharing options...
blake918 Posted December 11, 2003 Share Posted December 11, 2003 bbsal, do you still have the pics of your car after you installed the hids? I think your origional post got wiped out with the server crash . Quote Link to comment Share on other sites More sharing options...
SpeedRacer959 Posted December 11, 2003 Share Posted December 11, 2003 I've had that problem with a different car and there is somethign called dielectric grease (also called "bulb grease") that you can use to increase conductivity. It maybe connecting enought to work, but not fully. If you dont' have bulb grease, then WD-40 is great for electrical circuits, just use it sparingly. Let us know if that works. Quote Link to comment Share on other sites More sharing options...
blake918 Posted December 11, 2003 Share Posted December 11, 2003 Ahh welcome back Jimmi, long time no see(figurativley speaking of course ) :D :D How have things been? Quote Link to comment Share on other sites More sharing options...
SpeedRacer959 Posted December 11, 2003 Share Posted December 11, 2003 More for a personal message, but doing ok. Business has been sporatic lately...Really really busy, then really really slow. I think when the Lexus poses no maintenance problems, it's easy to drift from the board. The thing just hummmms. I'm still looking at the LS someday. Cheers! Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 11, 2003 Author Share Posted December 11, 2003 thanks guys. i will go check the connection points. Quote Link to comment Share on other sites More sharing options...
Latoilette Posted December 12, 2003 Author Share Posted December 12, 2003 i sanded it down and put dielectric grease and put it back in. problem still exists. any more help would be really appreciated. i never ran into a problem like this one before. Quote Link to comment Share on other sites More sharing options...
doiturself Posted December 13, 2003 Share Posted December 13, 2003 Check the housing connector make sure the contactor sticks out enough to make contact with bulb. I suspect that one of your house is not fully made contact to your light bulb. Quote Link to comment Share on other sites More sharing options...
Lex94 Posted December 23, 2003 Share Posted December 23, 2003 I have the same problem with the right turn signal on my 94. But it comes and goes. Front and rear light bulbs work, but the thing blinks rapidly sometimes. I told the dealer about this when I test drove it. He said they checked it out and it was fine. That was a few weeks ago before I bought it, now it's mine and probably my problem. The headlight housing now has condensation in it so it may be related to that. Has anyone on this post been successfull in fixing this problem or finding the cause? By the way, what's the recommended method of clearing the condensation from the headlight? The dealer wanted $750 to install a new headlight unit. Fuget it! I'm beginning to feel like I bought an Austin Healy or Triumph with all the electrical quirks this thing has. Thanks. Quote Link to comment Share on other sites More sharing options...
