Struts Or Ball Joints?
BlackLex
:huh:
I just bought a 94 LS 400 with 125,000 mi.
After I had it for about a week I noticed that the whole care tilts
toward the left (drivers side) about 3/8" in front and about 3/4"
in back. Could this be caused by worn suspension parts?
I ran a carfax on this car and there was a minor rear end
collision reported back in 97. I looked under the car and inside and out
of the trucnk and everything looks good . seller told me that paint was
original.
This car drives great and tracks down the road straight.
But I do get some suspension noise (sounds like upfront) when I
hit a larger bumb usually when going slower in town driving.
It may be my imagination but it seems worse when car is cold.
Driver's side tilt is not as abnormal as you may think.
Here is a way to lower the other side about 3/4" if you are interested[rod is 3/8" threaded rod]. Was a thread on this but think it is in the missing ones.
The rod is not in the spring---it is on the outside of it. And works just fine.
OR you can install new springs on the drivers side,OR take the springs off the passenger side and grind off enough to drop 3/4" and then heat and flatten the end then grind a flat on it !!
Rather have the rod--or even the tilt[isn't noticable anyway]
Hi BlackLex!! :)
My '93 LS is also lower on the driver's side. Never really noticed it until I saw it from a distance in a Costco parking lot. I can get 4 fingers [and a bit] between the passenger side fender and the rear tire and only 3 fingers on the driver's side. It's about the same on the front. [maybe a little less] From the responses - I take it that the springs are the cause. Are they that expensive to replace?
I used to have suspension noise - but that was taken car of when the sway-bar bushings were lubricated. Now it's very quiet. [even over speed-bumps - which is where the noise was most obvious] Maybe that's what you're hearing.
Craig!! :)
I noticed the same noise problem on my 91. I was thinking it was the sway bar ( stabilizer ) bushings as well. I am replacing them this week once I receive them. (~$50) I didn't think to lube them. I figured anything rubber and exposed underneath this well aged car is by now hardened and not up to par.
Craig--what did you lub the swaybar bushings with??
Hi tansupplyman!! :)
Sorry - I don't know what they used. The sway bars were 'dropped' and the bushings were lubricated by someone at my Lexus service centre. They didn't replace them because there were no signs of cracks or whatever. But it was a night and day difference. That crunching sound really wasn't very nice!!
Craig!! :)
Based on all the posts on this subject, it appears that a left tilt is not abnormal for an old 400 !!!!! Mine was almost identical to yours and I am not looking at all [and I have an Autolifter in my garage]. Don't think anyone has seen a tilt to the right; at least in the USA.
Craig--just remembered: the swaybar lub should be silicone grease[made for rubber and waterproof];generally comes in small tubes. Polyurethane bushings should use Molybdenum Disulfide grease.
I took a look and everything looks good all the bushings and ball joints .
I measured again and seems like about 3/8 in front 3/8 in back I can live
with it I'm the only one who can notice it.
I'm going to try to lube the sway bars and see if that doesn't cure the
crunching sound. I bet it will!
Thanks again every body
I'll post after lube
:cheers:
Thanks craig!!!
Last night I lubed up the sway bar bushings with a
silicone lubricant spray from prestone and then took my
car out for a spin on the same roads that caused the sounds
from my front end. Low and Behold they were gone! HURRAY!!!
Cost to me ... pennies .
I hope that that spray is safe for the rubber does anybody
know for sure? And I wonder how long it will last? I'll keep you all
posted.
Love my car,Love this club
That's great to hear - BlackLex!! [or great NOT to hear - I guess I should say!!] Isn't it nice when something so annoying is 'cured' by doing something so simple? It doesn't happen often - but when it does.... !!!
Did it say anything about bushings on the Prestone label? I'm sure it's OK. And IF that noise comes back [and it might - with only one 'shot' of lubricant] just spray it again!!
I bet when you go for a drive NOW you head straight for the bumpiest roads you can find!! lol
Craig!! :D
