Sign in to follow this
H8R Proof
Seat Belt...
...on driver's side isn't "springing" back into place after releasing the lock on the buckle. I have to kind of feed it back into place.
How to fix?
Share this post
Link to post
The retractor in the b pillar needs to be replaced. Pretty common, my Explorer has the same problem but its not worth the $$ to fix it.
Share this post
Link to post
sometiems it is dirt along the panel slowing down the belt
try pulling the belt all the way out and cleaning it with spray nine
and for best results take off the panel ,clean the inside of it and then as much of the components as possible for the retractor
Share this post
Link to post
just a thought..did maybe the belt get twisted at some point and retract all the way back so now you cant even see if it is twisted? take off the panel and check the whole seat belt and make sure its not twisted inside there.i had a simlar problem like that and it was that!
Share this post
Link to post
i woul say it is easier to see all of the belt
but you don't have to if you don't want to make sure
also the panel in fornt of the belt has just a few clips or plugs
so just pull it away from the pilar and it pops off
Share this post
Link to post
Loading...
