Rya Posted June 8, 2007 Share Posted June 8, 2007 How do I gently remove the dealership badge from the rear of my RX? I forgot to ask the dealer not to stick it on when they we're prepping my RX - duh! Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 8, 2007 Share Posted June 8, 2007 Heat it up with a hairdryer, It will peel right off. Then give it a polish and wax. ;) Quote Link to comment Share on other sites More sharing options...
Rya Posted June 8, 2007 Author Share Posted June 8, 2007 Heat it up with a hairdryer, It will peel right off. Then give it a polish and wax. ;) Merci! Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted June 9, 2007 Share Posted June 9, 2007 Just make sure you don't rub the excess glue off with anything that's too rough. It will scratch... Quote Link to comment Share on other sites More sharing options...
Rya Posted June 16, 2007 Author Share Posted June 16, 2007 Is a microfiber towel ok? I know not to use paper towels on the painted surface. Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted June 16, 2007 Share Posted June 16, 2007 Is a microfiber towel ok? I know not to use paper towels on the painted surface. Microfiber is perfect, just make sure not to press in too much. When you remove the badge there may be some excess glue still on the paint. Buy this product called GooGone and dab a little on the glue with your finger tip. Let it soak for a few minutes then gently rub with the microfiber. DON'T use your fingernail to scrape it off; the glue will eventually come off with gentle rubbing of the towel. good luck :) Quote Link to comment Share on other sites More sharing options...
Rya Posted June 17, 2007 Author Share Posted June 17, 2007 Thanks! We might have some GooGone still.... had a dilemma with some tape-on accessories that came off of my old Cherokee. I know - no more tape-on stuff... ever! (I was in the industry, mfgs sent samples that just happened to fit my vehicle). Quote Link to comment Share on other sites More sharing options...
penza1200 Posted June 28, 2007 Share Posted June 28, 2007 How do I gently remove the dealership badge from the rear of my RX? I forgot to ask the dealer not to stick it on when they we're prepping my RX - duh! If it's one of this stick on hard plastic badges you can remove it by using a piece of dental floss to slide behind it and saw back and forth to cut through the adhesive strip. Quote Link to comment Share on other sites More sharing options...
Rya Posted June 28, 2007 Author Share Posted June 28, 2007 Thanks for the suggestion. Eventually I'll have time to do this! Quote Link to comment Share on other sites More sharing options...
smooth1 Posted July 27, 2007 Share Posted July 27, 2007 Seeing as how the last post was in June, have you had time to do this yet??? Quote Link to comment Share on other sites More sharing options...
Rya Posted July 27, 2007 Author Share Posted July 27, 2007 Seeing as how the last post was in June, have you had time to do this yet??? Ummmmm, was waiting for the hubby to do it. Needless to say, it's still there.... I suppose I'll have to follow the advise and do it myself. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted July 27, 2007 Share Posted July 27, 2007 otherwise everyone is gonna start buying cars from that dealership!!!! Quote Link to comment Share on other sites More sharing options...
Rya Posted July 27, 2007 Author Share Posted July 27, 2007 otherwise everyone is gonna start buying cars from that dealership!!!! Ugh.... Quote Link to comment Share on other sites More sharing options...
