Tires, Can't Wait Might Go Toyo!
I have these on my BMW X5 and they have been great. Handle well in dry, wet and solid in snow. Quiet and a good side wall for cornering.
Toyo Tires
They do not come in our size but there is a very close match with some extra width.
Toyo Proxie S/T 255/50/18 V rated, load 106, max pressure 50lbs.
SIZE Diameter Width Weight
OEM 235/55/18 27.9 9.5 29lbs
Toyo 255/50/18 28.3 10.2 34lbs
The difference in height is almost within normal tread wear.
With the Toyo's you would be 0.5% off so when you are going 60mph your speedo would read 59.7mph.
Let me know what you all think. I may pull the trigger since the Bridgestones are on 4-6 week backorder.
Had Toyo Transpath OEM tire way back on my a Nissan Pathfinder SE back in '99 and I must say that they were awesome tires. That's where I forged a new found respect for Toyo, since I had never owned or would of even considered them purchasing them. I was impressed with there product back then.
Cheers,
MadloR
I have no experience with Toyo's; I assume they're Japanese? If they work as well as the Yokohama's I have owned they should be great tires at reasonable prices.
Tom
