VMF Posted August 20, 2003 Share Posted August 20, 2003 strange thing i noticed about my car. when i'm braking and speed is already very small car tends to turn right. i mean the steering wheel is turning by itself for like 30-40 degrees. why would that happend Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 20, 2003 Share Posted August 20, 2003 Make sure the caliper slide pins are good and lubricated, one of the calipers is either sticking and not compressing fully, or one is compressing too far. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 21, 2003 Share Posted August 21, 2003 another option is there is air bubles in one side more than the other causing more compression on one side to of blanace the system get them checked and bled Quote Link to comment Share on other sites More sharing options...
leo Posted December 17, 2003 Share Posted December 17, 2003 Could also be that your car is out of alignment as my car acted similarly. Alignment took care of the problem. Just make sure you take it to a shop that works on Lexus as these cars have many adjustments to get it properly aligned. Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 18, 2003 Share Posted December 18, 2003 have your mechanic check the front control arms on your vehicle....there is a rubber bushing on those vehicles that wears out...if this is the case it will usually cause a loud thump going over bumps..but not always....it is possible that one of these has worn out on your car. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted December 18, 2003 Share Posted December 18, 2003 Brooklyn, check your tire pressures, then your right front caliper is probably hanging. The easiest way to check if it is hanging is to put your hand on it after driving and feel if it is hotter than the other side. Brooklyn roads are tough, but it's probably simiple. Crap gets in tha caliper boots and hangs them up. Denny Quote Link to comment Share on other sites More sharing options...
VMF Posted December 18, 2003 Author Share Posted December 18, 2003 ITS BEEA WHILE SINCE I ASKED THIS. CHANGIN TIRES SOLVED THE PROBLEM THANX GUYS! Quote Link to comment Share on other sites More sharing options...
