Please Advise!
does any know if the navigation head unit for the 99 GS400 will fit the 2000 Gs300? does it integrate easily? Please let me know, I found a kick !Removed! deal. What also is part of the nav system....cd rom, any other parts to the unit itself?
Thanks for the help.
It'll fit, but the install is very involved and requires a lot of custom wiring.
The nav should consist of the:
-Head unit
-Hard Drive
-Antenna
-Wiring harness
It also has a vehicle maintenance deal and a trip computer.
LOTS of wiring, I think it was estimated at 24 hours of labor. Its been done though.
if you can find a good deal, i'd definitely pick it up. it'll certainly add more value to your gs. i'd go talk to your lex dealer and see how much they'd charge to install as they'll be able to do it right. keep us posted, as it's something i've been thinking about doing as well.
Also, dont forget speed sensor computer, speed sensor itself. You might run into audio issues if your going from NAK to Premium or vice versa ie. amp, speaker ohm loads etc. Your better off just buying an aftermarket system. It would probably cost the same, 3k, but at least you could also play movies, have much faster mapping, and the newest software and other technology. If your capable of installing this yourself and feel comfortable removing panels and carpeting and are mechanically and electrically inclined, then go for it.
