Do they come with instructions as to how to extinguish the failed tail and stop light diagnostic..?
From the page it mentioned that it has a transformer. I think all it really has is a few load resisters inside to balance the current and keep the warning off.
Well, since you asked, I don't like them. They look too much like some teenage addition to the Lexus. You know, the ricer look. Just my opinion.
Gary
They aren't bad, but I've always thought that the stock one's look pretty good. But it's whatever you like.
Hope your bid gets accepted though. Good luck.
Saw yesterday that the first of the LED headlights will be in a 2007 model car. Don't remember which one, though. It is only for driving lights and low beams - for now. It's a great solution for lights, since they almost never wear out, cost far less than expensive headlights, and use much less electricity than current models do.
  • 4 months later...
I've been using LED bulbs/lamps in my 2001 996 C4 since new and updated my 2001 RX300 to them about a year ago. Recently changed out the original LEDs in the RX300 for a set from V-LEDs off of Ebay. I've been tolerating the bulb failure indicator on the dash rather than use additional load resistors but today I pulled the rear bulb failure detection module out and will be modifying it so its satisfied with the lower current draw of the LEDs.
