mdls400 Posted April 14, 2006 Share Posted April 14, 2006 ok..here is the problem with my 1992 LS400..i just relplaced the alternator and the power steering pump in it and was running fine after i was done..the next day i get in it to go to work and when i take off it starts to hesitate..when i start the car it idles fine and all but once it's put into gear you can feel a little hesitation and when you take off it hesitates..can somebody please help me figure this one out?? thanks.. Quote Link to comment Share on other sites More sharing options...
RFeldes Posted April 14, 2006 Share Posted April 14, 2006 Re Check Alternator and Battery connections and all vacuum lines. Quote Link to comment Share on other sites More sharing options...
Threadcutter Posted April 14, 2006 Share Posted April 14, 2006 ok..here is the problem with my 1992 LS400..i just relplaced the alternator and the power steering pump in it and was running fine after i was done..the next day i get in it to go to work and when i take off it starts to hesitate..when i start the car it idles fine and all but once it's put into gear you can feel a little hesitation and when you take off it hesitates..can somebody please help me figure this one out?? thanks.. Did you replace the Air Control Valve (ACV) when you replaced the Pump? It should be replaced at the same time because if the pump is leaking the ACV has probably been dead for a while. The good news is that you don't have to remove the pump to replace the ACV. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted April 15, 2006 Share Posted April 15, 2006 CHeck the intake pipe for leaks Quote Link to comment Share on other sites More sharing options...
zigenfiver Posted August 12, 2006 Share Posted August 12, 2006 I had the same exact problem with my 1992 LS400, and I cleaned my throttle body, fuel system, checked vacuum lines and replaced the Throttle Position Sensor, none of this solved my problem. I finally took it to my Master Mechanic, and he diagnosed the problem. He tested the plugs and wires and found that the RH ignition coil was bad. He replaced the coil, distributor cap and rotor on the right side. Car runs great now. Quote Link to comment Share on other sites More sharing options...
HomerTHX1138 Posted August 16, 2006 Share Posted August 16, 2006 Mine had hesitation at low throttle. Throttle body cleaning helped. A large bottle of techron completed the job. Quote Link to comment Share on other sites More sharing options...
