Has anyone towed the limit of 3500 lbs on your 400h? I found a boat that with trailer and boat weight came to a close 3450 lbs! I know it can pull it fine, but I am more worried when I am pulling it out on the wet loading ramp...
Thanks,
James
i believe the tow hitch limit is 3000 pounds...but thats probably just a safety sticker, it could probably go way more than that. and if im wrong...call me and ill help you pick up the peices of your bumper and stuff.
Thanks,
James
If the tow hitch is installed by Lexus, I doubt it'd be rated at only 3000 lbs. Liability-wise, that wouldn't be a good move on their part.
The 3500 lb limit is with trailer brakes. I believe limit is 2000 lbs without.
I have several thousand miles with about a 1500 lb lboat oad and no trailer brakes. Except for killing the gas mileage pulls fine.
Ron
Oh, heh..good thing I read this thread. I almost bought a 3400lb boat today! I guess I will buy another jet ski instead of a boat.
Thanks..
Thanks..
Just get a boat like mine, it pulls just fine and weighs about 2000 pounds with the trailer. XB2002 (20foot) Allison with a 260 Merc outboard. It looks real cool behing the Lexus and will run 100+ MPH on the water. You will love it.
Bob
Thanks..
Bob
Yeah, I concluded that if I bought any decent size boat, it would be a bass boat. Every other boat is around 4000 lbs. I actually ended up buying a MB SLK 280 instead, heh. Talk about a 180! I just figured I could get more use out of the car than the boat. That will be next years purchase..
Thanks for all your thoughts
