GSR2IS300 Posted March 14, 2006 Share Posted March 14, 2006 When I first put the car reverse or drive after I start it and I begin to pull out or back out, the first time I tap the brakes there is a loud clicking sound that sounds like its coming from all sides of the car. It only happens when I first start driving, the first time I use the brakes, but after that I don't hear it anymore. Any ideas? Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted March 15, 2006 Share Posted March 15, 2006 lol yes, i have that too. might have to do the the floating calipers on the IS. just another annoyance of this 30 thousand dollar car. Quote Link to comment Share on other sites More sharing options...
bartkat Posted March 15, 2006 Share Posted March 15, 2006 It is the floating front calipers. They all do it. Quote Link to comment Share on other sites More sharing options...
cruznroadking Posted March 15, 2006 Share Posted March 15, 2006 Called brake pad shift . This is a normal condition. Other cars do this as well. Quote Link to comment Share on other sites More sharing options...
GSR2IS300 Posted March 15, 2006 Author Share Posted March 15, 2006 Called brake pad shift . This is a normal condition. Other cars do this as well. I feel good that I'm not the only one. That is wierd that is a "normal" sound coming from a Lexus. I wonder if there is anyway to fix that? Quote Link to comment Share on other sites More sharing options...
lenore Posted March 15, 2006 Share Posted March 15, 2006 maybe the spring clips that bias against the upper and lower portion of the pads is compressed or broken. Look very carefully, the pads should fit very snug in the clips with no up or down movement. Quote Link to comment Share on other sites More sharing options...
caraveli Posted March 15, 2006 Share Posted March 15, 2006 maybe the spring clips that bias against the upper and lower portion of the pads is compressed or broken. Look very carefully, the pads should fit very snug in the clips with no up or down movement. I dont have it Quote Link to comment Share on other sites More sharing options...
ccjw33 Posted March 16, 2006 Share Posted March 16, 2006 I only have the clicking noise when my car is stopped or moving forward under 5mph. I just called Lexus today to find out if they can fix this problem but they said they never heard any problem with the noise. I used to drive MB E320 and it had the same noise but it was the air compression noise so it's total different than Lexus I think. Quote Link to comment Share on other sites More sharing options...
bartkat Posted March 16, 2006 Share Posted March 16, 2006 maybe the spring clips that bias against the upper and lower portion of the pads is compressed or broken. Look very carefully, the pads should fit very snug in the clips with no up or down movement. I dont have it He's talking about IS300. Quote Link to comment Share on other sites More sharing options...
ccjw33 Posted March 16, 2006 Share Posted March 16, 2006 maybe the spring clips that bias against the upper and lower portion of the pads is compressed or broken. Look very carefully, the pads should fit very snug in the clips with no up or down movement. I dont have it He's talking about IS300. my bad but IS350 also has little tickling noise from the hood. Quote Link to comment Share on other sites More sharing options...
bartkat Posted March 16, 2006 Share Posted March 16, 2006 maybe the spring clips that bias against the upper and lower portion of the pads is compressed or broken. Look very carefully, the pads should fit very snug in the clips with no up or down movement. I dont have it He's talking about IS300. my bad but IS350 also has little tickling noise from the hood. That's the direct injectors. Quote Link to comment Share on other sites More sharing options...
