VMF Posted July 16, 2003 Share Posted July 16, 2003 should i do a tune up for my stransmission or i should not? that is the big question. i dont know when and if the previuos owner ever changed the oil in transmissino. but it smells burned from there when i check the oil. i know it might die if i will change the oil now. or it will not on lexus. i have a big lack of knowledge regarding this. any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
jzz30 Posted July 16, 2003 Share Posted July 16, 2003 why would it die if you change it? Quote Link to comment Share on other sites More sharing options...
SRK Posted July 16, 2003 Share Posted July 16, 2003 The idea that changing the oil may endanger the trans (or engine or whatever) is a huge myth that has been around for years. It simply isn't true. If the trans does die after changing the oil, it is because the oil was changed too late, and the trans was going to die anyways. Change it now. Lexus has a very reasonable service interval for the trans which should be followed. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 16, 2003 Share Posted July 16, 2003 change it it is meant to be on my es i don't have a filter in there either so it is just flush and fill since the filter is just a metal mesh rather than a media to be replaced although a good shop should remove and clean it by lowering the pan and cleaning the magnet as well,so the gasket should replaced the cost of the filter a normal tranny service goes for about 100 a nice system to use is the one that attaches to the tranny cooler lines and after it has warmed up and the valve has opened it can then remove all the fluid ion the body of the trans and the torque convertor which can hold about 3 liters alone Quote Link to comment Share on other sites More sharing options...
jzz30 Posted July 16, 2003 Share Posted July 16, 2003 if your going to remove the trans oil pan throw in one or two more magnets just for the hell of it because it does catch some gunk that doesnt look good for the trans :o Quote Link to comment Share on other sites More sharing options...
ToddLS400 Posted July 16, 2003 Share Posted July 16, 2003 should i do a tune up for my stransmission or i should not? that is the big question. i dont know when and if the previuos owner ever changed the oil in transmissino. but it smells burned from there when i check the oil. i know it might die if i will change the oil now. or it will not on lexus. i have a big lack of knowledge regarding this. any help would be greatly appreciated I had the same thing with my LS400 when I bought it a few months ago. The burning smell is from too much fluid in the tranny and torque converter. The tranny fluid is burning! You need to have as much fluid drained as possible then have it refilled to the correct level. It takes 2-3 drain and refills to get all of the fluid out of the torque converter for a full flush and refill. Quote Link to comment Share on other sites More sharing options...
VMF Posted July 16, 2003 Author Share Posted July 16, 2003 i dont know any local stores i would trust with my tranny, i used to have chrysler concorde and my tranny died couple of times while the tranny was on warrany, once it died rite in the store when i came to pick up the car:) how much would dealer charge for this procedure? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 17, 2003 Share Posted July 17, 2003 not sure if the daler has the machine to do the full flush and fill just a drain and fill it is a very simple machine it just uses a collector and the tranny cooler and return line so instead of the fliud going to the cooler it goes in the machine to cuiculate until it is warm since there is a heat activated switch for the tranny to warm up the fluid which stops the full flow inside until it reaches operating temp once it does see the increased flow it stops the cuiculation of the old fluid and lets the tranny drain right into it while the other line sucks up the new fluid to replace what has just left Quote Link to comment Share on other sites More sharing options...
VMF Posted July 17, 2003 Author Share Posted July 17, 2003 goin to the dealer on fri, will ask him about the price on this as well thanks! Quote Link to comment Share on other sites More sharing options...
Jasoneo5 Posted August 14, 2003 Share Posted August 14, 2003 Anybody have pictures on this? I really don't want to pay the lexus dealer to do it 2-3 times but I want to give my trans. a good flush myself. Pictures would be very helpful or detailed information would be also. I am willing to give a "donation" if it is wanted to whoever can provide me with the info because I really need it. Jasoneo5@comcast.net Thanks so much for your time as it is always greatly appreciated! Best Regards, -Jason Elcan Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 14, 2003 Share Posted August 14, 2003 Yeah you definately want to go ahead and do it, but just make sure that you use the correct fluid, the same fluid used at the factory, the Toyota fluid. I definately reccomend the flush, you should have the engine flushed too one of these days. Gets the old crud out of there that dirties the new fluid as soon as its changed. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted August 14, 2003 Share Posted August 14, 2003 Change it. Driving it the city where you shift all the time really wears out the fluid. Besides, I know you won't sleep well knowing there is old fluid in your tranny. I change the trans oil in all my cars every two years and I'll bet that guy in Utah with 555,000 miles does too. I also flush the cooling system and brake lines at the same time. I had the Lexus dealer do mine but I suspect they just did a drain and fill. You REALLY want the system SWO talked about, it's the best because your torque conerter fluid is also changed. Finding someone to do it right is another story.... anywhere! Hey, just flipped on the news about the blackout in NYC so I guess VMF won't be reading this right away. Hot air, warm beer, no computer. Ugh! Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 14, 2003 Share Posted August 14, 2003 Yeah how about that? I though about VMF too. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted August 14, 2003 Share Posted August 14, 2003 I guess he'll have to cruise around Brooklyn tonight. I was there for a big blackout in 1977 and lemme tell you, they tore some stuff up. Tough place to be with no power. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 14, 2003 Share Posted August 14, 2003 I can only imagine... Quote Link to comment Share on other sites More sharing options...
VMF Posted August 16, 2003 Author Share Posted August 16, 2003 i was sleepin in the car for the most part of the night and went to Nj to chill over my GFs house:) so whats the exact name of the thing for flushign the tranny? i really need to flush the tranny and power steering coz it seems like my power steering is dying on me. Quote Link to comment Share on other sites More sharing options...
