chrisnisbet Posted September 16, 2005 Share Posted September 16, 2005 I have a couple of 'spare' parts that were left in the trunk of the car when I bought it a while ago, and I can't find where they are meant to go. One says F/L and the other says R/R, so I assume they go front left and right rear. The part numbers are: F/L: 67774-50020 R/R: 67775-50030 I've attached a picture of them. Does anyone have any idea where they go? Cheers. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 17, 2005 Share Posted September 17, 2005 Can't tell ,what are tehy made of plastic vinyl metal? Quote Link to comment Share on other sites More sharing options...
sha4000 Posted September 17, 2005 Share Posted September 17, 2005 looks like molding Quote Link to comment Share on other sites More sharing options...
chrisnisbet Posted September 17, 2005 Author Share Posted September 17, 2005 They're plastic. It looks like the underside of them should be stuck with adhesive to another surface. I was hoping that someone might be able to look up the part numbers to see what they are called/where they should go. The finish on the 'top' side of them is such that I wouldn't expect it to normally be visible. I wondered if they might be some kind of drain tray that fed A/C condensate away somewhere. They're prety clean, which makes me think they go inside the car somewhere. Cheers Quote Link to comment Share on other sites More sharing options...
Lexls Posted September 17, 2005 Share Posted September 17, 2005 I looked in my parts book and there wasn't anything......what year LS? There were a few part #'s close to it (they change them sometimes) and they were for the rear door panels. Quote Link to comment Share on other sites More sharing options...
chrisnisbet Posted September 17, 2005 Author Share Posted September 17, 2005 Mines a '95. LHD as well, which might make a difference Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 18, 2005 Share Posted September 18, 2005 looks like a sill plate by the base of the doors Quote Link to comment Share on other sites More sharing options...
chrisnisbet Posted September 18, 2005 Author Share Posted September 18, 2005 Cheers. I'll take a look. Visible without taking the door apart do you think? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 18, 2005 Share Posted September 18, 2005 Not on the doors but the plastic that sits on the carpet by where the seat and door meet. Quote Link to comment Share on other sites More sharing options...
chrisnisbet Posted September 18, 2005 Author Share Posted September 18, 2005 Nope, that's not the spot. Maybe someone will be able to use thos part numbers to work out where they go. In fact, I might give the local dealer a call today to see if they can help. Quote Link to comment Share on other sites More sharing options...
OLDMANLEX Posted September 18, 2005 Share Posted September 18, 2005 Nope, that's not the spot. Maybe someone will be able to use thos part numbers to work out where they go. In fact, I might give the local dealer a call today to see if they can help. ← Quote Link to comment Share on other sites More sharing options...
OLDMANLEX Posted September 18, 2005 Share Posted September 18, 2005 I have a couple of 'spare' parts that were left in the trunk of the car when I bought it a while ago, and I can't find where they are meant to go.One says F/L and the other says R/R, so I assume they go front left and right rear. The part numbers are: F/L: 67774-50020 R/R: 67775-50030 I've attached a picture of them. Does anyone have any idea where they go? Cheers. ← Quote Link to comment Share on other sites More sharing options...
chrisnisbet Posted September 18, 2005 Author Share Posted September 18, 2005 sorry OLDMANLEX, I didn't see your comment. Could you repeat please? Quote Link to comment Share on other sites More sharing options...
chrisnisbet Posted September 19, 2005 Author Share Posted September 19, 2005 Well, the dealer tells me that the part numbers look legit, but that his computer doesn't have any knowledge of those part numbers. Sigh. Quote Link to comment Share on other sites More sharing options...
svarog Posted September 19, 2005 Share Posted September 19, 2005 Probably not from the car then or from some other car. Quote Link to comment Share on other sites More sharing options...
billydpowell Posted October 18, 2018 Share Posted October 18, 2018 this same part is in my 99LS, I am thinking under the seat in some way, I am 84 and cant get down there to look anymore without much pain.. IMG_0046.MOV Quote Link to comment Share on other sites More sharing options...
billydpowell Posted October 20, 2018 Share Posted October 20, 2018 I will put an end to this mystery..... these are the trim finish panels that fit the "hole" in all 4 doors, you cant see them, but your fingers feel them when you use the opening to close the door.... they seem to fit 95-2000 1 Quote Link to comment Share on other sites More sharing options...
billydpowell Posted January 21, 2019 Share Posted January 21, 2019 On 9/16/2005 at 4:57 PM, chrisnisbet said: I have a couple of 'spare' parts that were left in the trunk of the car when I bought it a while ago, and I can't find where they are meant to go. One says F/L and the other says R/R, so I assume they go front left and right rear. The part numbers are: F/L: 67774-50020 R/R: 67775-50030 I've attached a picture of them. Does anyone have any idea where they go? Cheers. you are right. they go in the "POCKET" on the doors as a trim panel at the top.. glue them in.. Quote Link to comment Share on other sites More sharing options...
