Sc400 - Error Code 15
Hmm - anybody else have anything more specific?  I actually have to communicate this to a friend who has my car - and am not sure what they have loosened off to get access to change the ignition wires ...
12
RPM Signal
13
RPM Signal
14
Ignition Signal
15
Ignition Signal
16
Electronically Controlled Transmission Control Signal
17
CMP No. 1
18
CMP No. 2
21
Main O2S & Heater Signal
22
ECT Sensor Signal
24
IAT Sensor Signal
25
Air–Fuel Ratio Lean Malfunction
26
Air–Fuel Ratio Rich Malfunction
27
Sub O2S Signal
28
Main O2S
29
Sub O2S
31 & 32
Air Flow Meter Signal
35
HAC/Barometric Pressure Sensor Signal
41
TP Sensor Signal
42
VSS Signal
43
Starter Signal
47
Sub TP Sensor
48
Secondary Injection System Malfunction
51
Switch Condition Signal
52
KS Signal
53
Knock Control Signal
55
KS Signal
70
EGR System Malfunction
71
78
Fuel Pump Control
thank for your help .
My friend took everything apart again and put it back together and then it worked ... must have goofed up a connector or something..
this is the 50th time I've learned this lesson .."if there is something simple and straight forward to do on your car - then do it yourself, because no one will be as careful and gentle on your car as YOU would be!!"
