Can Anybody Help Me Program My Remote Key
thats not the right remote for your car.the fcc# should be HYQWDT-B not the 1512.the 1512 is just a remote and the one you need has the button on the side of the key and the model number is HYQWDT-B.thats why its not working for you.check on ebay and you can find the right one.
actually the procedure is made to resync your key with the alarm brain
not add a new one
as from the manual
" open the drivers side door, others closed
using the door lock control switch
perform " lock , unlock " operation 10 times within 30 seconds
keep each state for about 1 second
less than 2 seconds after performing the above
continue to press the transmitter switch for 10 seconds
does nothing
if it locks 2 time the codes do not match the rom and ecu
3 times transmitter fault
hi, I tried that procedure, after doing it, the door locked and unlocked once, and thats all, what does that mean? Thanks.
once should mean it works fine
are you having problems ?
to fyounes
sorry i have to many threads to check to replay to all
but has the remotes ever worked on your car?
i might ponder to say there is a problem with the set
and your only option is the dealer and get a new ecu chip and 2 keys to match f you wan t it to work
sorry there is no short cut as the double lock tells you
it sees the remote but since it does not match what is inside the ecu it will not respond to it
  • 1 year later...
Hello,
I have a '94 ES300 which I got without a remote or a remote key. The key that I use is just a regular key. I know the car has an alarm though(set it off a couple of times, and it has the volume control for it next to the mirror control). I was wondering how I would go about getting a remote for the car. Would an aftermarket remote from Autozone work, or do I have to get a Lexus OEM remote? If someone could enlighten me on this, it would be much appreciated.
Thanks,
Elazar
  • 6 months later...
hey ppl,
i just got a 96 es300, and bought this remote key from lexus-parts.com, fcc id hyqwdt-b.
however, i was unable to program the key by following bbsal's procedure.
after the steps, i heard beep (door locked), and beep beep (door open) twice instead of just one "beep".
i tried pressed buttom simutenusly, still not working. holding the buttom, obviously not working.
wut should i do when i get to the beeping part since its more than one beep?
I bought a remote key on ebay for my 93 ES300 , i read the topic an d i followed the instruction given in a previous topic, like turn ign twice . lock un lock dorrs, 5 times...i did that and i was suppose to hear a beep, but i never did. does anybody know how? thanks
Try turning ignition once not twice-it worked for me. gsgas@adelphia.net
  • 4 years later...
not add a new one
as from the manual
does nothing
I know this thread is from years ago but im just havin this problem. After i did the steps the car beeped once then after a short pause it beeped again i held the button on the key but it didnt do any thing. Am I doing this right or what can someone help please
