lilme Posted January 31, 2005 Share Posted January 31, 2005 I have 17500 miles and the inner tread on all 4 tires is gone, as in 2/32 left. The other treads have 8-9/32 left. Possibly another 15000 miles if the alignment had not gone out again. :cries: I have had it aligned 2 times and the tires rotated 3 times. I've done what I should. Is there a problem with camber in this car?? I will have to replace all 4 tires. Quote Link to comment Share on other sites More sharing options...
AWJ Posted January 31, 2005 Share Posted January 31, 2005 #1 complaint on those my man... they wear out too fast... many people put regular radials in their place... Quote Link to comment Share on other sites More sharing options...
johnny3 Posted January 31, 2005 Share Posted January 31, 2005 Yes, it's the R.F. tires, you've done well to get that many miles from them. The people that are changing to conventional radials are much happier with their 430's ride & quietness. Quote Link to comment Share on other sites More sharing options...
lilme Posted January 31, 2005 Author Share Posted January 31, 2005 #1 complaint on those my man... they wear out too fast... many people put regular radials in their place... ← Thanks. But is the alignment, specifically the negative camber what is ruining the tires? Will the new, standard tires I put on be ruined prematurely also? That is what I need to know. Quote Link to comment Share on other sites More sharing options...
johnny3 Posted February 1, 2005 Share Posted February 1, 2005 I think the RF tires have such a stiff sidewall that the edeges wear-out prematurely. A conventional radial is much more forgiving as the soft side-wall lets the face of the tire stay flatter on the pavement. --johnny Quote Link to comment Share on other sites More sharing options...
rockriv Posted February 21, 2005 Share Posted February 21, 2005 I have 17500 miles and the inner tread on all 4 tires is gone, as in 2/32 left. The other treads have 8-9/32 left. Possibly another 15000 miles if the alignment had not gone out again.:cries: I have had it aligned 2 times and the tires rotated 3 times. I've done what I should. Is there a problem with camber in this car?? I will have to replace all 4 tires. ← My SC430 front tire inner threads havea also worn after about 12K miles on the Dunlops. Let me know what you figure out. I'm replacing the Dunlup run flats with conventional tires. Quote Link to comment Share on other sites More sharing options...
psolov Posted February 22, 2005 Share Posted February 22, 2005 This is normal wear for that tire. Swap it out with the Michelin Pilot AS tires and save about $125 per tire and get 20k miles more. Use $50 to get AAA if you have a flat. I have 17500 miles and the inner tread on all 4 tires is gone, as in 2/32 left. The other treads have 8-9/32 left. Possibly another 15000 miles if the alignment had not gone out again.:cries: I have had it aligned 2 times and the tires rotated 3 times. I've done what I should. Is there a problem with camber in this car?? I will have to replace all 4 tires. ← Quote Link to comment Share on other sites More sharing options...
914lps Posted February 22, 2005 Share Posted February 22, 2005 What dose the tire shop and Alinment shop tell you. They shoul be able to tell you if it is the car or the tires. You can even call around to dierant tire shops and ask them. If you ask 3 shops and get the same responce from 2 it is most likly right. Quote Link to comment Share on other sites More sharing options...
