Simpion Posted January 4, 2005 Share Posted January 4, 2005 Our 2003 ES 300 has 13,000 miles. While my wife was left front break seized up and the wheel began smoking while going 30 MPH (Thankfully she was only going 30 MPH). The Lexus dealership says the break fluid is contaminated and the entire break system (hoses, valves, calipers, pads, master cylinder, etc.) need to be replaced at a cost of $5,200 plus tax. My non-Lexus mechanic tells me replacing everything is not necessary. He would inspect the system and replace parts as needed. The dealership says none of this is covered by the warranty because they believe the contamination is oil. The warranty is void if fluids other than those recommended in the owner's manual are used. We don't have a full service history on the car as we bought it in an insurance company stolen car auction. However, they Lexus dealership was able tell us the car had the 6,000 mile service. I have researched brake fluid contamination. Everything I read tells me the most likely source of the contamination is water, not oil. My research indicates the oil would cause various parts to deteriorate almost immediately. We had the car for 6 weeks with no signs of brake trouble. Also, the car sat for over 4 months on the insurance company's lot. We have appealed the dealership's decision with a regional Lexus service rep. Has anyone had to deal with this type of situation before? We don't want to take it elsewhere for fear that Lexus will not pay for the repairs if they are done elsewhere. I have read about services that can analyze brake fluid to determine the source of the contamination. But, by the time we get the kit to do the extraction, send it off to the service and get the results it could be 6 - 8 days. Meanwhile, we are paying for a rental car. Any thoughts, advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
bartkat Posted January 5, 2005 Share Posted January 5, 2005 You might want to get the test kit anyway, because it may be that long before you get a decision from Lexus anyway. How did the dealership do their tests? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 5, 2005 Share Posted January 5, 2005 agreed a test kit should be perfect for id any potential void of warr Quote Link to comment Share on other sites More sharing options...
Simpion Posted January 5, 2005 Author Share Posted January 5, 2005 You might want to get the test kit anyway, because it may be that long before you get a decision from Lexus anyway. How did the dealership do their tests? ← We don't know. We think it's an assumption based on the color of the fluid. Thanks for your reply. Quote Link to comment Share on other sites More sharing options...
bartkat Posted January 5, 2005 Share Posted January 5, 2005 You might want to get the test kit anyway, because it may be that long before you get a decision from Lexus anyway. How did the dealership do their tests? ← We don't know. We think it's an assumption based on the color of the fluid. Thanks for your reply. ← When I had my 30,000 mile service I asked why they do a brake fluid flush and change. I had never had that done on a car before. It was explained to me it was because of the possibilty of water contamination. This agrees with what you posted earlier. Quote Link to comment Share on other sites More sharing options...
monarch Posted January 5, 2005 Share Posted January 5, 2005 If a significant amount of motor oil or other petroleum substance like that was ever added to the brake system then the Lexus dealer is correct that all the expensive hydraulic componets of the brake system might be ruined and have to be replaced. Personally I would buy 4 quarts of DOT 3 brake fluid and flush the brake system out myself and hope that the new fluid restores brake system performance. To do a real thorough job you should try to suck a quart of fluid out of each brake bleeder valve located on each of the 4 brake calipers. You might want to also check the other lubes and fluids in the car too (coolant, engine oil, transmission oil, power steering fluid) for signs of accidental or intentional contamination / sabotage. Quote Link to comment Share on other sites More sharing options...
steviej Posted January 5, 2005 Share Posted January 5, 2005 what color is/was the fluid that they think was contaminated and fluid analysis would answer some questions. If it is not contaminated then you would have to think mechanical defect. Could have been a faulty caliper or brake line that got crimped or clogged. I guess with smoke being created then the caliper on that side has damage now and any defect may be masked. Are the pads done to nothing on that side? Check the rubber gasket/boot on the caliper for any tears and check the brake line under that wheel well for any crimps. this will be interesting to see how it plays out. steviej Quote Link to comment Share on other sites More sharing options...
mxl4729 Posted January 5, 2005 Share Posted January 5, 2005 buy a vacume bleeder and suck out all the old fluid through the bleeder screw and replace it with new and then take it to another Lexus dealer and have them check it out and see if you can get them to fix it. also the most part that costs the most in replacing the system would be the abs unit. rather then new you can get them online for about 200 with a 1 year warranty that would save you a 1000 bucks or so if u end up having to have the job done. Quote Link to comment Share on other sites More sharing options...
Simpion Posted January 14, 2005 Author Share Posted January 14, 2005 Well it turns out the State Farm (from whom we bought the car in an auction) did not run a history on this car. The Lexus dealership ran one and we discovered the car was considered totaled and had odometer issues. The date of the totaling was right around the time of a major hurricane in Sept 03. Our theory is the car was caught in a flood and the owner decided to have the car stolen and relocated. We had received a notorized letter from State Farm prior to the sale stating the car was not a total loss vehicle. We can't believe State Farm had not run a history on the car. State Farm recently settled a case in which they were found to be sellling cars with falsified histories. After we contacted them with the car's history they agreed to take the car back and make us whole on any costs associated with the sale and ownership of the car, as well as the cost of a rental car while we search for a new car. We are car shopping this weekend and will consider another ES 300. We loved the care while it ran and our experience with Lexus of Cherry Hill, NJ was very positive. I may be back on this board as a Lexus owner. Bye for now. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 14, 2005 Share Posted January 14, 2005 how nice Quote Link to comment Share on other sites More sharing options...
vcv10guy Posted January 14, 2005 Share Posted January 14, 2005 Wow that's quite an outcome on your whole situation. Good thing State Farm didn't give you any hassle on returning the car. Good luck finding another ES, and hope to hear from you soon. :) Quote Link to comment Share on other sites More sharing options...
