johnbmech Posted December 28, 2004 Share Posted December 28, 2004 I have a new 05 RX330. The owners manual states I can manually program the door locks for opening & closing. I tried to set the door locks to "unlock" when pulling the ignition key & nothing changed. Doors have to be unlocked manually or with the drivers side unlock button when exiting the car. I phoned the dealer-He said the doors have to set using a scan tool at the shop. Is this correct & the manual is wrong? Quote Link to comment Share on other sites More sharing options...
4482 Posted December 28, 2004 Share Posted December 28, 2004 I have a new 05 RX330. The owners manual states I can manually program the door locks for opening & closing. I tried to set the door locks to "unlock" when pulling the ignition key & nothing changed. Doors have to be unlocked manually or with the drivers side unlock button when exiting the car. I phoned the dealer-He said the doors have to set using a scan tool at the shop. Is this correct & the manual is wrong? ← Yes it is true. The dealer did mine. My doors are programed to lock @ 12 MPH and unlock when I put the shift into park. They used a hand-held unit for the programing. Quote Link to comment Share on other sites More sharing options...
04RX330 Posted December 31, 2004 Share Posted December 31, 2004 I did it myself just following the instruction from the owner's manual. Quote Link to comment Share on other sites More sharing options...
lordzatez Posted January 5, 2005 Share Posted January 5, 2005 If its not to inconveiniant hop into your dealer they should have you in and out in 10 min or less. To bad they dropped the ball and did not give you a personalized features check list at the time of sell and had you check off what you wanted preprogramed at time of delivery. Lexus is really pushing its dealers in that direction this year Lexus Ninja Guy Quote Link to comment Share on other sites More sharing options...
Booyah Posted January 5, 2005 Share Posted January 5, 2005 You should be able to get with your dealer and the Mech will go over all the C-Best setting with you right at the car with tool in hand and ask you what you want! Mine did I also did the door lock thing on my own by the owners manual. My doors lock when in D and Unlock when I put it in P Quote Link to comment Share on other sites More sharing options...
scottl Posted March 4, 2005 Share Posted March 4, 2005 You should be able to get with your dealer and the Mech will go over all the C-Best setting with you right at the car with tool in hand and ask you what you want! Mine didI also did the door lock thing on my own by the owners manual. My doors lock when in D and Unlock when I put it in P ← How did you do the door lock thing? Does it work on a 2001 RX300? Quote Link to comment Share on other sites More sharing options...
cruznroadking Posted March 4, 2005 Share Posted March 4, 2005 Go to the dealer to have it programmed. On the 2005 models they'll do it free the first time as long as you do it within the first year. Quote Link to comment Share on other sites More sharing options...
lexdog Posted March 4, 2005 Share Posted March 4, 2005 Can the locks on a rx300 be programmed manually ? Quote Link to comment Share on other sites More sharing options...
cnynctry Posted March 11, 2005 Share Posted March 11, 2005 How did you do the door lock thing? Does it work on a 2001 RX300? ← Went to the dealer today and was informed that the 1999-2002 RX-300 does not have the capability to program c-best settings. I wanted to change the lock and unlock and change the head lights to stay on only for 15 seconds vs. 30. They said it's not programable. I was shocked. Keith Quote Link to comment Share on other sites More sharing options...
