RanGer498 Posted December 21, 2004 Share Posted December 21, 2004 is there a way to make the guages at night as bright or almost as bright as when its day time ? i never noticed till just a few weeks ago that my guages cluster lighting dims lighter the darker it gets out,it doest look bad but i would like it brighter ..i have the adjustment knob all the way to bright so im kinda stumped on what to do . many thanks. Quote Link to comment Share on other sites More sharing options...
TWINTURBO619 Posted December 21, 2004 Share Posted December 21, 2004 well when I turn up the dimmer in my car, they're too bright, so I have them on the halfway mark. I have no idea why yours are not bright enough. Quote Link to comment Share on other sites More sharing options...
BA_GS400 Posted December 22, 2004 Share Posted December 22, 2004 well when I turn up the dimmer in my car, they're too bright, so I have them on the halfway mark. I have no idea why yours are not bright enough. ← No idea's dude. I can sympathize somewhat because sometimes I find that mine are not that bright. I was beginning to wonder if there was a noticeable difference when you are at engine idle, or at higher RPM's where the alternator would put out more juice. (just a thought) Quote Link to comment Share on other sites More sharing options...
dsvetcov Posted December 24, 2004 Share Posted December 24, 2004 I am glad someone else realized this. I too thought it was me or was there a voltage leak? Let's just call this automotive enguniuty. ;) Curious if this is noted in the owner's manual. Happy holiday... Quote Link to comment Share on other sites More sharing options...
doublesharp Posted December 24, 2004 Share Posted December 24, 2004 My 2000 GS400 dash is a bit dim even turned up all the way. Acceptable but not as bright as I'd like. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted December 24, 2004 Share Posted December 24, 2004 it's NOT a good idea to turn up your dimmer to full brightness on the older GS's. As twinturbo and I do, leave it at about half way, it's more than bright enough in our cars. The most important reason to NOT turn them up full brightness is that in the older GS's those bulbs put out ALOT of heat. I recently put LED's in mine and all the bulb bases were brown and brittle from the heat. The MOST important reason not to turn them up all the way is it can lead to early needle failure from the heat created. The needles are NOT cheap! B) Quote Link to comment Share on other sites More sharing options...
DaSwede_420 Posted January 4, 2006 Share Posted January 4, 2006 it's NOT a good idea to turn up your dimmer to full brightness on the older GS's. As twinturbo and I do, leave it at about half way, it's more than bright enough in our cars. The most important reason to NOT turn them up full brightness is that in the older GS's those bulbs put out ALOT of heat. I recently put LED's in mine and all the bulb bases were brown and brittle from the heat. The MOST important reason not to turn them up all the way is it can lead to early needle failure from the heat created. The needles are NOT cheap! B) does anyone know where to get good aftermarket bulbs?? mine's burned out already on the temperature indicator(so at night i have no idea what the temp is... lol) Quote Link to comment Share on other sites More sharing options...
