Fog Lights Vs Signal Lights -sc300
CLightning
But  some people wire them to look like foglights.My friend did that so his cornering lights are on when is headlights are on.I think they look better that way.Wish i knew how to do it.
Sounds like that might be illegal.
Not as simple as changing the bulb as the beam pattern of the light is about 45 degrees off center. A better option would be to install aftermarket fog lamps in the vehicle or buy the fog lamps for the 96+ and install them. An upgrade of the vehicle wiring may be required for the additional current draw of fog lamps versus cornering lamps.
