jahon Posted November 8, 2004 Posted November 8, 2004 Took me six hours to remove my fuel injector properly to get to the rear valve cover gasket and spart plugs to change them out. In this process i also cleaned out the air filter box and throttle body. Today I will spend the day putting it all back together, plugging back in sensors and bolting everything back on. I think I saved hundreds of dollars doing this myself.. Oh, I'll get some pictures later if I remember..
sunman Posted November 8, 2004 Posted November 8, 2004 i changed all the valve cover gaskets, PCV valve, fuel filter, cam and crank seals, ,timing belt, water pump. I don't remember removing any fuel injectors for this work though?
mxl4729 Posted November 8, 2004 Posted November 8, 2004 Took me six hours to remove my fuel injector properly to get to the rear valve cover gasket and spart plugs to change them out. In this process i also cleaned out the air filter box and throttle body. Today I will spend the day putting it all back together, plugging back in sensors and bolting everything back on. I think I saved hundreds of dollars doing this myself.. Oh, I'll get some pictures later if I remember.. ← why were u removing the fuel injectors and were are the pics
jahon Posted November 9, 2004 Author Posted November 9, 2004 were they making some noise ? ← yes, i cleaned it all out though. its prrrrrrrfect now. i swear to god i am never going to sell my car after putting this much work into it. i changed the front and rear valve cover gaskets and put in new platinum +4 sparks. i also cleaned out my throttle body.
