***Edit*** Skip to post #5 for update
Dealer says "intake meter" needs to be replaced. I'm assuming its the air intake meter. I've done a thread search and have checked on the sponsors links for this part. Does it go by another name?
Thanks in advance.
In the repair manual for my 93 LS 400, this part is called the "Volume Air Flow Meter."
I don't have a repair manual for the ES; however, I would assume they would use the same terminology.
It is obviously the same part as the Mass Air Flow Sensor.
Why do you need to change your maf?
They are pretty much indestrucable and sometimes need to be cleaned only,or their is a rip in the intake tube forma broken engine mount
This is what the dealer said was causing the engine light to be activated.
UPDATE:
Took car back to dealer to verify the part - It is the MAF. They wanted $400 to replace. I have located a part for much less, but not sure if it is necessary.
Should I just disassemble (using Haynes manual) give it a good cleaning and put back. I so, what to clean with?
clean it you have nothign to lose.
It normally is the intake pipe not the maf causing a problem.
Inspect it for rips.
Also, I was looking for the tutorial section to see if there was anything on it. Can someone point me to that section, I don't see it. Thanks
Yes, I found it cleaned it, restarted car 3-4 times to try and reset warning light. Still on. I was looking for the tutorial section for general info and future reference, I have a haynes manual. Would anyone care to point me to the tutorial section. Thanks
on the opening page
under lexus maintance it is there
or scroll down to near the bottom of the bar below to the right that says
lexus es250/es300/es330
Ironworker, since you cleaned it, i'm not sure if this would help... but don't forget to leave one of the terminal on your battery out to try to reset it. I usually leave it out for either 1 hr (i know you don't necessarily have to leave it that long) or i just leave it out for the whole night n go to bed... n wake up in the morning n put it back in. It should reset your computer.
Which tutorial r u looking for?
