sunman Posted September 7, 2004 Posted September 7, 2004 I bought a 97 ES300 a few weeks ago and tried the seat heaters. they don't heat at all. The illumination works on the switch. Also, when the switch is turned on, the orange indicator turns on the switch to let me know they are on. I checked under the seats. There are 2 connectors with 2 wires each. One of the 2 pin connectors has power to one of the pins no matter which position the heated seat switch is in so I assume that is for some other feature. The other 2 pin connector is dead. No power to it at all even with the switch turned on. No power to either lead. I checked the fuse and it is ok. No blown at all. Is there a relay? The engine rpm remains constant when the switch is turned on so I assume it is not drawing any load any where when switched on. What else can I check? Both drivers and passangers seat do the same thing. Everything else works perfectly in the car. I was wondering if the climate control has anything to do with it?
SKperformance Posted September 7, 2004 Posted September 7, 2004 check the vdc at the batt terminals after the car is hot and idling
amf1932 Posted September 7, 2004 Posted September 7, 2004 Disconnect the connectors and check with an ohmmeter to see if there is any resistance to the seat heaters. If you get a zero reading on the meter it means the heating element(s) are defective.
sunman Posted September 7, 2004 Author Posted September 7, 2004 even if the elements are bad, I should be getting power at the connector. Also, the battery voltage remains the same with the switch turned on.
pearlwhite97ES Posted March 22, 2005 Posted March 22, 2005 hi, new to the forum thanks for having a place to read! My97 es300 has all options and the only thing wrong is the drivers side heated seat. Question is there a relay that could be out? or is it the element in this seat? any advice would be helpful ty
amf1932 Posted March 22, 2005 Posted March 22, 2005 hi, new to the forum thanks for having a place to read! My97 es300 has all options and the only thing wrong is the drivers side heated seat. Question is there a relay that could be out? or is it the element in this seat? any advice would be helpful ty ← Read my previous post! :whistles:
eman_be_lexin Posted March 22, 2005 Posted March 22, 2005 I noticed the same problem with my seat heaters but never checked the resistance at the connection points under the seat. I did take the switches out of the console and noticed that there are 2 adjustments (pots) on the switch. What are these adjustments for? Do they increase the heat level to the seats?
Senna4ever Posted March 24, 2005 Posted March 24, 2005 I have a problem with my driver's side heater, too. My problem is that the seat gets too hot...it will not turn down the heat like it used to. It is literally gets hot enough to burn. Just the element under my left butt cheek does this. Any ideas/suggestions what could be wrong?
