pangobo400 Posted August 30, 2004 Share Posted August 30, 2004 i have a 92 lexus sc400 and i was wondering if the engine has a timing belt or a timing chain...and how often should i change em and where it's located at under the hood...thanks! Quote Link to comment Share on other sites More sharing options...
silvermate Posted August 30, 2004 Share Posted August 30, 2004 its a belt you can do a search in the SC forums (this is the detail forum) and find all the info you will need......its been talked about many times....... Quote Link to comment Share on other sites More sharing options...
j_lee84sc Posted September 1, 2004 Share Posted September 1, 2004 Ha...i like changing timing belts about as much as i like someone bashing my teeth in with an aluminum bat..... your timing belt is a belt running your cam gears and crank pulley....it drives your engine's timing with precision and great accuracy...or else...kaboom! dont mess with it unless you are somewhat familar with it... you can have it professionaly replaced for around 250-350 dollars...it is well worht it for the less experianced!! Quote Link to comment Share on other sites More sharing options...
renolexus Posted September 1, 2004 Share Posted September 1, 2004 i have a 92 lexus sc400 and i was wondering if the engine has a timing belt or a timing chain...and how often should i change em and where it's located at under the hood...thanks! Timing belt, it can be seen if you remove the distributor and rotor cap covers, it's the two black covers located in front of the motor, when removed it makes belt visible. Quote Link to comment Share on other sites More sharing options...
