I've 97 ES300. I went to Toyota service center for oil change and tire rotation, they told me I need to change all the rotors which were in bad shape for $1k. When I drive my car, everything seems normal. I'm not sure if the dealer tries to rip me. Can anyone please tell me what's the symtoms for bad rotors? How dangerous would it be for driving with bad rotors? Thanks very much.
if your wheel vibrates when braking at high speeds then it is warped
if it is older and has worn down or badly it will have gouges and be thinner than the min spec for them.
If you're worried about dealership costs for the parts, you can purchase similar parts at http://www.irontoad.com. They're operated by Thompson Lexus in PA, and known to inventory factory Toyota/Lexus parts at much cheaper prices than at local dealerships. I ordered front brake pads and rotors from them a while ago for my '01 ES, and they arrived at my door the very next day after I placed my order (talk about fast service!). I'm very pleased with the way they handled the transaction, and would definitely do business with them again :cheers:
I've ordered from them as well and had great experiences with them. Had a problem with one of my orders one time and they took care of it right away hassle free.
when in doubt, always get a second opinion.
Go somewhere where they will not charge you for the diagnostic.
As stated previously, if you don't have any vibration when applying the brakes at any speed or pressure, then I would say you are pretty much set.
steviej
Can wheels can also vibrate because of...
glazed rotors and wet road?
Along the same lines... when can rotors be turned, and when do they need to be changed? I had a bad vibration in my steering wheel last November and had the rotors turned. Now, nine months later, the vibration is back. Is it normal to have rotor problems so often? (I haven't had the problem diagnosed, but I'm 99% sure that's what it is... it's the same vibration that was there before.) I had the first repair done at the dealership... do they guarantee their work?
rotors warp due to heat being diffused unevenly or over heating such as a bad way of braking or having hot rotors running through water
each time you turn/lathe/resurface a rotor it removes metal which causes the rotor to warp even faster again
Replacing your rotors/pads is extremely simple. I would highly recommend doing it yourself. Pick yourself up a hanes manual for $13.95 or go to your library and borrow one.
The whole job will take you about 2 hours and cost you about $200 if you do it right. Check ebay, they have lots of cheap parts there for your car. Here's a start:
Front rotors: $50 shipped
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33564
Rear rotors: $50 shipped
Then you can buy stock brake pads from www.iroantoad.com or whereever for ~$100. Beyond that, just make sure you read the manual first and you have everything all set such as two cans of brake cleaner etc.
They are no special tools required, just a socket/wrench and a floor jack.
I just replaced the rotors/pads on my wifes Sienna XLE which is strickingly similar to the ES300. It only took me about 2 hours front and rear.
Even if you decide to not do it yourself, you can buy all the parts and take it somewhere to have them put on.
Good luck.
:cheers:
