I have had some probs postin some im back as newbig400.My gs400 is shaking from about 60 up.I have z rated tires and had it aligned at the dealer and balenced where I bought the tires.I dont understand I read somewhere about a bushing but I cant find it now.It also pulsates through the brakes sometimes not all the time but sometimes really bad.It makes them feel like theyre warped.I know theyre not I have new cross drilled and slotted Brembos with ceramic pads.Does this sound familiar?What could it be?Also does anyone know about tightening the throttle cable if so how much and do u adjust at the throttle body? :wacko:
My 99 GS300 has a bit of the same problem every now and then. I think my 18s are the brunt of the problem. I'm planning on switching back to my stock wheels for a few weeks to see the difference. i can't imagine 20"+ wheel rattle....
GS400's (all GS 1998 and up) have no throttle cable. They are drive-by-wire. Your size-12 merely tells the throttle body motor how much to open. There are no adjustments.
that bushing you referenced is kind of like a lower stiffening brace.
you can find lots of info on it at www.clublexus.com.
I believe that the balancing that they do to our rims/tires is usually at 35-60mph and that's it....
anyway, that bracing arm is about 12" long or so and I believe it's around $100 at the dealer. (unsure if that's each, or for two)
My '98 GS300 with Stock 16's does the same thing.
Sometimes it shakes, sometimes not. I had "Road Force" balancing done, and still have vibration.
Also pulstates when braking sometimes...
no idea what problem is.....just wanted to let people know you can spend a fortune on new wheels and tires and still have this prob.
Would be nice if Lexus Dealers would help just a little.
:lol::lol::lol: Guytelefunken , Sorry but the 98GS + Has a throttle cable and is controlled by computer , DARN , ALEX TRIBEK WOULD HAVE BEEN PROUD. !!!!! :lol::lol::lol:
JUST HAVING FUN :cheers: GUY
Major cause of vibration problems are:
1. upper control arm bushings ($1299)
2. transmission mount ($158)
pictures
Can you post some pics of the bracing arm?
hmm..i will have to ask about these, since I will be intalling Coilovers sometime soon, anyway. my vibration is not that bad, and only @65-70 mph (bad cruising spot).
