All Activity
- Past hour
KjwStL45 joined the community
- Today
RX400h started following Lexus 2002 es300 and Engine Cover Bolt
Did you contact the parts department person at the dealership? Or try one or more Lexus OEM parts sites, such as: https://parts.lexus.com/ https://lexuspartsnow.com https://lexusoeparts.com
I'm not sure if this description is perfectly accurate, but it may be worth a try/look:
slabman started following Engine Cover Bolt
2007 LX470, 4.7L V-8 Engine 2uZFE. Does anyone know the size of the bolts for the engine cover shroud? I need the one closest to the Rt. front of the cover. I seems to be a 6MM flange bolt, approx 6 in. long? I can't find a source anywhere and my local Lexus dealer is of no help.
Me neither. It's hard to understand his popularity.
Mike Thibodeaux joined the community
I have a 2002 Lexus es300. Put battery in wrong. 120 amp fuse blew. I pull fuse out but cartridge came out but seem like blades are still in. I’m afraid to pull really hard. All the fuses I by are male. I don’t think there is a female. Should I pull harder . I hate to tear something up. Need advice
randy2000 joined the community
dcfish started following Scotty Kilmer
Can't stand Scotty....
currus joined the community
SancarHTX joined the community
Hi, Is anyone else having this issue? My car only has 30k miles and is making this noise again, took it to dealer and they had both the trailing arms replaced under warranty, the noise went away temporarily, now it’s back but not as loud. It only happens vehicle is driven trough potholes or bumps. I have the F sport trim.
OldManCar started following Scotty Kilmer and Floor Mats
Same issue.Tan mats look off and the Ecru shade is hard to match. Let me know if you found a solution.
Recently watched one of his videos where he disrespects an SC430 with 700,000 miles(!!!) Amazing sacrilege.
OldManCar joined the community
Antenna Mast Replacement On 2004 Sc430
OldManCar replied to jpwonderdog's topic in 01 - 10 Lexus SC430
I recently bought a super clean 2005, and they fully disclosed the antenna was broken, as in the motor runs but the antenna remains in the fully extended position. I've thought about a modern black replacement (shorty) but kind of want to stay original. Most SC430's I've been around exhibit the same problem. Great car. -
Headlight Problem, Low Beams not working on 2012 RX 450h
Newdadx2 replied to Newdadx2's topic in 10 - 15 Lexus RX350 / RX450h
Thank you for your response! I do understand that it is possible, but not likely that both bulbs could burn out simultaneously. However , my main focus is on the relay. But, I honestly have done a lot of research to identify the low beam relay, but I cannot find any information on how to find it -
You should try one or more of these online sites: https://parts.lexus.com/ https://lexus.oempartsonline.com/ Genuine OEM Lexus Parts and Accessories Online - Lexus Parts Now
Perhaps it is related to the seatbelt connection or door that is not fully closed, although I would think that either of these would result in an illuminated symbol. I would check the seat belt and door switch.
BETTYBOOPSTER joined the community
- Yesterday
elcamino85 joined the community
DarrylSandri joined the community
Rodsrx started following 99 RX300 bell going off
Have 250k on it with new battery and alternator. For some reason now when I'm driving there is a bell tone that goes off about every minute. And just one chime at a time. When parked it doesn't. Appreciate any help. Thnx Rod
Rodsrx joined the community
I have the same problem now with my sc430. All bottoms operate but the mode switch will not change the direction of airflow. It is stuck blowing on the window. Nothing changes when I send it to the floor or in my face.
I have the same thing on my 2015 Lexus Sport has only 88,000 miles--and was previously repaired by dealer 4 yrs ago for the same thing when car was under Certified Warranty. I have recently read it's a flaw that Lexus thought was fixed in 2010--but all are not holding to that. I' not happy as I've totally maintained and cared for the auto!! Let me know if anyone has a good ideas. I don't know whether to trade as is or repair and keep awhile. But what happens when people see 2 timing chain repairs on carfax?? I have 1 estimate at $4000--but it's more of a "mom and pop" shop. Not sure how many Lexus they repair.
I posted the thread Popping sound and still have it after read sway bar links changed and new shocks I have decided to replace the rear sway bar bushings. It appears to be straight forward. My problem is finding the right Rear Sway bar bushings. I find a lot of front bushings but not rear. The bar is 3/4” , 9mm. I have tried the local Autozone, Advanced Auto Parts, Oreily’s and Rock Auto. Maybe I am doing my searching incorrect. 2014 Lexus RX350 rear sway bar bushings. Have also tried Rear Stabilizer Bar Bushings. Any help appreciated.
- Last week
Both of the low beam headlights stopped working recently, and I can't seem to find any information that might be helpful to resolve the issue. I've checked the fuses for each side, and they are intact, do I would assume that because they both stopped working simultaneously that it would be a relay or ballast issue, and not light bulb or fuse. But I have exhausted my online search to find where the low beam relay would be located, to test and/or replace. Is there anyone who can identify the specific relay that controls the low beams? Or, am I asking the wrong question?
2007 RX 350 Hatch NOT WORKING
Paige Deaver replied to Paige Deaver's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
I’m going to try all suggestions and will reply. I appreciate your efforts. Frustrated in The Ville! -
RX400h replied to Paige Deaver's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
Great. Patience/persistence is the key!
Ok so I figured out what the problem was. The adjuster bolt is actually seized in the pinch block. This is why I couldn’t lower the alternator enough. I ended up completely removing the lock bolt to get the alternator out, so I could get a look at it. Right now I have the car running with the alternator held in place only by the top mounting bolt being tight, hehe. I need to get a new pinch bolt, adjuster bolt, and pinch block, now…
Thank you, AO.
The hatch on my RX 350 isnt working. Any suggestions?
Topics
