All Activity
- Today
Tony Haman joined the community
SQLS400 joined the community
ABQISHOME joined the community
Hotfox joined the community
- Yesterday
Silverfox4264 joined the community
O2 sensors changed. still no help with rough idle. car starts fine. Lexus claims it's due to faulty fuel injector system flooding the right cylinder bank. they claim fuel injection system is unavailable. any ideas? spent about $4500 to fix and still have the problem could you a little advice. thx / Rog
JKSims started following Power Window Switch Battery Drain
Thanks! I have done reprogrammed the windows for sure. I'm going to start looking at a junkyard, but it'd be awesome to find an aftermarket.
A bit of an update. Have had the LS460 on a battery tender all winter. Car hasn't been driven for about 35 days, prior to unplugging the tender. Took it off two weeks ago as I was going away and didn't want to plugged in while I was gone. Got back, measured the battery voltage, still at 12.67 after 14 days just sitting. So the good news is, for longer term sits the car must go into a deeper sleep than what I was first measuring. Once it has sat un-driven for a month or so, the draw must drop to nearly nothing as 12.67 is virtually a fully charged battery. If the draw had remained at even 40 Milliamps, it would have drawn it down more than that. So a battery in good condition, and a car stored in heated indoor storage, no alarm armed, appears to be able to sit for very l;ong periods of time without flattening the battery.
RX400h started following Power Window Switch Battery Drain , Codes on my 2008 GX 470 and TX500h
When this light comes on, it’s important to get your vehicle inspected by a professional as soon as possible to prevent any potential damage. It’s hard to say exactly what the issue is without a proper diagnosis. Your Lexus dealer or a trusted mechanic should be able to read the specific error code from the OBD system and determine the exact cause of the problem. That being said, I should also advise you to check or have checked your battery. Sometimes a failing battery or even a cell with no visible liquid in it can cause very strange warning lights to illuminate.
Hello, Chris. Car & Driver's observed fuel economy was 23 mpg: 2024 Lexus TX Hybrid Review, Pricing, and Specs (caranddriver.com)
Hello, Justin. Have you already tried reprogramming the power windows? Turn the key to the on position. At each window switch, lower the window to halfway, then immediately raise it all the way up and hold the switch up for at least 1 second. Repeat this process for all 4 doors Also, you may get lucky in finding a wrecked GX470 at a scrap yard.
JKSims joined the community
My wife's 2007 GX470 was having battery drain issues. I tracked it to the little lights on the power window switch never turning off. I pulled it and it looked like an aftermarket unit. I bought another aftermarket unit and sure enough, I had the same problem. Has anyone had any luck with replacing these with something. Non-OEM? I'm not paying almost $700 for that part from Lexus.
Scot Michael joined the community
500Chris joined the community
I have a 2024 Lexus TX500h Luxury and drive both freeway and city. The best and average I a seeing is 21.4 MGP. I took it in to dealer and they hooked it up and said it is running properly. With the advertised MPG at 27/28 that is 20% below expected and most of the time even driving thought parking lots is in gas mode. Looking at the TX350 Luxury is rated at 21/27. Is there anyone with the same problem?
shax joined the community
Frank4207 joined the community
- Last week
dcfish started following Codes on my 2008 GX 470
Did this just happen all of a sudden ? No previous lights on the dash ?
Thanks for confirming that there isn't any set tightening order. I just did a crisscross pattern with gradual tightening all around. I do want to note that the torque specs on that website are not accurate. Haynes 3MZ-FE manual shows 71 in-lbs for the both front and rear valve covers. Moreover, there was another gentleman who commented on a youtube video that he noted that the Toyota's 3MZ-FE shop manual showed 71 in-lbs also (however, I can only personally attest to the Haynes Manual which I own). In that DIY youtube video, the mechanic relied on the website you suggested and overtorqued the valve cover bolts to 9 ft-lbs (108 in-lbs), causing one of this bolts to break! So, I would highly suggest following more reputable sources like Toyota/Lexus service manuals and Chilton/Haynes Manuals.
Tail lights come on after vehicle is shut off
RX400h replied to bendutton17's topic in 01 - 06 Lexus LS430
S
bendutton17 started following Tail lights come on after vehicle is shut off
So I just bought myself a 2005 LS430 after a few years of searching. I've had it a little over a month and I absolutely love it. However, over the last couple days, I've noticed my tail lights coming on for seemingly no reason. First time I noticed, I thought it was just a trick of the light, as the sun was getting low and figured it was just the sun hitting my lights just right to give the illusion of them being on. Fast forward to this morning; I had to leave earlier than usual for work, so around 4:45am, came out my front door, and low and behold, clear as day, my tail lights are on (not brake lights, just tail lights, and literally nothing else). My first thought was "uh oh, did I leave my lights on all night?" Which I was all but certain I hadn't. After confirming they were in fact off, next thing I checked was my brake pedal. Didn't seem anything out of the ordinary, but just to see, I tried gently lifting it off it's rest point, to no result. Kicker was that, unbeknownst to me at that moment, as soon as I hit my keyless entry, lights immediately went off. Upon discovering the lights were off, I went to work like normal. Fast forward another hour or so, I get a message from a co-worker saying my tail lights are on. So now I know there's clearly an issue. After a quick search online, I couldn't find much, but I did find something about a possible ECU in the trunk, or 'luggage room' as was described on the website. When I returned to my car after my delivery, the tail lights were on again. So I decided to test something; I hit the unlock on my keyless entry, and then waited. As soon as I hit the button, lights went off. Then, after around 30 seconds, they came back on. Then tried the lock button, same result. So fast forward again to the end of my work day: I go run some errands real quick and head home. When I got home, my first instinct was to pop the truck to make sure no water was getting into places it shouldn't, and thankfully found no evidence of that. But the lights would still come on after about 30 seconds of hitting a button on my keyless entry. Now for the real interesting part: after feeling stumped, I popped the hood, as I was going to disconnect the battery to make sure it wouldn't drain, I had to run inside to grab my tools, so I closed the hood, ran in, and when I got back, the lights were off, and staying off. I've been home for about 45 minutes now, and keep checking regularly, and they haven't come back on yet (knock on wood). Any ideas as to what the issue could be? I've seen potential for it to be something as minor as a fuse to as major as a wiring harness. Any suggestions or ideas would be a hug help, thanks!
LexusLover1 started following Torque/Tightening Order for the (9) Rear Valve Cover bolts
vandine started following Lexus not having two keys for the 2023 RX
Report this to NHTSA as a safety and security issue. Lexus not sharing all the info, campaign is no longer listed on the app. I think they are trying to stuff the digital key down our throats, glitchy and unsafe as it is. Its all about profit.......
My GX470 had the following Codes come on this morning. Flashing check engine, The VSC, TRAC, or trailer sway control system is operating if the slip indicator light is flashing. If the indicator light is fully illuminated there is a malfunction in the VSC system, TRAC system, hill-start assist control system, or trailer sway control, and you should have the vehicle inspected by your Lexus service provider immediately. This warning light indicates a malfunction in the electronic engine control system, the electronic throttle control system, or the electronic automatic transmission control system. Whenever this light turns on you should have your vehicle inspected immediately by your Lexus dealer. What does this mean? Enter You sent
Shifter interlock 2023 NX350
Mike Black replied to tak06's topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
I have a 2024 NX350H and I haven't noticed undue pressure needed. It does have to be pressed a fair bit -- probably much more than what it takes for the brake lights. Have you done a distance measure of the brake pedal to see the difference between brake lights and shifting? I'll have to check mine. -
Seanamus changed their profile photo
tak06 replied to tak06's topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
Thanks for that, I spoke to a Lexus service dept. and he stated that it's normal to firmly depress the brakes to shift into a drive mode, really annoying but I'll have to get use to it. The pre fly by wire system is so much better and user friendly. -
Mark Levinson sound system
filmlaw posted a topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
I am really interested in great car audio. Does anyone have any thoughts on how to set the treble, bass and midrange as well as how to balance the speakers to get the best sound from the driver's seat? -
RX400h replied to tak06's topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
What are the Possible Causes of the DTC P1127 Lexus? NOTE: The causes shown may not be a complete list of all potential problems, and it is possible that there may be other causes. Faulty Electronic Throttle Control System (ETCS) Actuator Electronic Throttle Control System (ETCS) Actuator harness is open or shorted Electronic Throttle Control System (ETCS) Actuator circuit poor electrical connection Read more: https://www.autocodes.com/p1127_lexus.html It may be that locating the specific cause is not exactly simple for the doityourselfer.
Topics
