Anyone experienced this problem or know how to fix it?
My 2000 RX300 stock Pioneer stereo works with the CD player but there is no sound with either the FM/AM radio or the tape player. You can select Tape or radio but there is no volume regardless of what it says on display.
I don't think it would be an amp issue since CDs play fine. I've been thinking about pulling out the stereo unit and resoldering everything but before I do I was hoping for some advice on what it might be and/or diagrams. I've checked and replaced the fuses (they weren't blown)
Thanks!
Hi, and welcome to the Forum
I would advise removing the head unit from the dash for external examination and see if you can spot anything obvious with wiring, etc if not then pull it apart to check...what have you got to lose, if it doesn't already work?
Let us know how you get on with it all
Cheers  Trevor
