Unknown Error
tinur5
Hello,
im new in the Forum and live in Europe. I drive my Lexus LS430 since 3.5 Years. As you can probably read im not a native English but i will try my best.
Ive got an Error on my Boardcomputer. It only say Check VSC. As far asi know this is an Error wich has an other root. I checked i with the Lexus guys and we found an Error on the OBD wich says that there is a valve damaged on the Air intake. As far as i understood him right, there is an valve wich swich on and off the last 2 Cylinders in a higher RPM Range.
Now i do not exactly understand the reason for this valve and i also do not know under wich Name i can search something like this. Do you have any suggesteon, where i can find some explanation about that valve, and Probably a spare Part?
Thanks for your Help
Martin
