Crossgolf Posted June 14, 2016 Posted June 14, 2016 When I open the trunk on or after a rainy day there is always water driping out from underneath the tail lights. The water comes out of the side of the trunk lid. Is this normal or is some sealing missing or maybe a drain hole clogged?
gwgang Posted June 15, 2016 Posted June 15, 2016 Did the water leak into the trunk? If not, no worry. There are molding between the light and the trunk opening. Water from up on the lift gate spoiler will drain around the trunk rubber seals, then under that plastic molding. Sometime when you manually open the lift gate too fast, some water will drip into the trunk too. Nothing you can do except to open it slowly when it's very wet outside.
