What Is This?
Toyota calls this a noise filter, but it's probably a bass cutoff filter that's used to prevent overloading the speakers at very low frequencies. You could call the Toyota Corporation or your Lexus parts dealer and give them the part number and ask them what it's used for.
A bass cutoff removes the extreme low frequencies(below about 30hz) that you wouldn't normally hear anyway, but sucks up the amplifiers power and uses this power for the audible range of frequencies.
As I said before, if nobody here can answer your question, get in touch with the manufacturer of the automobile.
If you took it out you'd probably hear more distortion at high volume levels, but this is assuming that the filter is used as a low frequency cutoff. I don't think it could hurt anything if you tried removing it though. ;)
