diesel2k Posted March 17, 2004 Share Posted March 17, 2004 I'm having trouble with my starter. I'll try and check to see if the connectors are dirty as described by some of the other members in this forum, rather than buying a new starter. But, if I do need to replace it, the guy at an Auto Zone store asked me if I had the starter with the cold climate package or the one without a cold climate package. Does anyone know what he's talking about? I own a 97 LX450. Any input would help. thanks guys Quote Link to comment Share on other sites More sharing options...
dougjohn Posted March 18, 2004 Share Posted March 18, 2004 If you're gonna tackle the starter rebuild, make sure you read up on this first: http://www.sleeoffroad.com/technical/tz_starter_rebuild.htm That said, there were 2 starters sold for all 80 series Land Cruises (1993-1997), which includes the LX450 (1996-1997). The smaller starter was installed on trucks sent to warmer weather locations and the larger starter was sent to colder locations -- not quite sure how they determined what/where was warm vs. cold. The cold climate starter is the 2.0 kW starter. The other is the 1.4kW starter. Prior to my owning my current LX 450, I owned a 1994 LC with a cold climate starter -- that thing cranked up instantly. My LX 450 has the warm weather starter which takes full second or two before it turns over. If you're replacing the entire starter, go with the larger (cold climate) starter. If you're not sure, you could check the starter itself, you should be able to see the 1.4kW or 2.0kW on it somewhere. Quote Link to comment Share on other sites More sharing options...
diesel2k Posted March 22, 2004 Author Share Posted March 22, 2004 thanks for the info doug john! Quote Link to comment Share on other sites More sharing options...
Rookie Posted March 26, 2004 Share Posted March 26, 2004 There seems to be a pretty common problem with the contacts on these things. You definitely should try replacing these first. Cheers, Rookie Quote Link to comment Share on other sites More sharing options...
