2000 Rx300 Loss Of Gas Mileage
TPH
Can anyone help with a sudden loss of gas mileage in a 2000 RX300 AWD. It dropped from just below 19 MPG to 16 MPG almost over night. Have cleaned the mass airflow sensor and changed the thermostat - was heating up slowly. Any other ideas?? No trouble codes. Runs well.
  • Like 1
checked the usual, tire pressure, air filter, and dont forget the change in fuel from winter to summer blends....With no cel lights hard to diagnose
Just had the CEL come on this morning on the way to work. Code 1150. I believe this is the Air/Fuel ratio sensor on the front bank of cylinders. Bet that could make a difference in mileage. Thanks for the input have checked all the other typical culprits. Was about to remove wheels and check for dragging brakes.
