mphubbar
Changing Brake Pads On A 2001
I have spent a fair amount of time searching about this on this forum and IH8MUD trying to find out what is necessary just to change the pads on my truck. Haven't been able to get a consensus, some say it is hard some say easy some say removing the calipers is necessary some don't, some say re-grease the piston some don't. Just wondering if there is a simple "how to" out there somewhere. I've changed the pads on my Volvo before and it was pretty simple, just assumed it would be similar here but the posts I am seeing are making me start to believe otherwise. Would appreciate any insights or info. Thank you.
Share this post
Link to post
Lots of views, no replies so I'll give you some pointers. My truck has 232K so I've done the pads a few times. ;)
1) the fronts are a "monoblock" style. this means that there are pistons on both sides. you will have to remove the calipers as they are not like what you might find on German cars (like my Porsche). Still, pretty easy. I think they are 15mm bolts. You'll need something to press the pistons back in to make room for the thicker pads.
2) The rears are slider style. On this case, there is a piston on only one side. What I found recently is that on each side, one of the sliders has a rubber boot to create some drag. mine were dry rotted. you can get new pins and rubber bushings from Advance Auto for cheap so I would recommend grabbing a set. If you lube them, get a tube of the slide lubricant, also at autozone. Don't use an all purpose grease because it causes problems with the rubber boot on the pin. these are also pretty easy but getting the snap spring off the outside is a bit of a pain.
Share this post
Link to post
The manual indicate removal of the front caliper. I tend to remove the bottom bolt and swing it upward to get at the pads. I used ceramic brake lube (from Advance Auto) on the backing of the pads and on the sliders mentioned above with good results - the brakes are very quiet. Both front/back disk pad replacements are easy from my perspective. I started out doing drum brakes for years, so disk pads are simple.
One of the key steps after the new pads is to break in the pads/rotors to each other. I take the vehicle out and do a series of about 10 stops from 60 mph down to about 5 mph. This heats up the pads and rotor and although fade can be noticed, the braking will feel smooth and consistent. I then drive at about 60 mph with no stops for about 15 min to let them cool down. It is important to never come to a full stop nor rest at stop with pads engaged during the breakin - or the pads will leave deposits on the rotor and you will have to start all over to get smoothness again. In an unexpected need to stop, I have used the emergency brakes to hold (uses a drum pad in the rear). The Superstop site had a good description for break in several years ago. I have used the method when brakes have become rough - i.e. pad deposits seem to be creating rough stops.
The 100 LC/LX have been unusual for me in that the rear brake pads wear out much faster than the front. I highly favor the OEM pads by Toyota, the only disappointment I can recall is with a set of TRD pads on the front.
Share this post
Link to post
Loading...
  • Similar Content
    • By knoxh458
      Hello everyone I will admit I am new to the forum service but I have just acquired a 2005 Lexus LX470 and would like to get some wheels/tires for it if anyone has an idea for me or wheels for sale I would be more than interested!
    • By RJD-LX470
      Hi,
      First post - I'm looking at buying a leather seat trim kit from Lseat - to replace my well worn front and middle seats.  Wonder if anyone on the forum has had any experience using a seat leather trim kit or with Lseat.
    • By datarecovery
      This is a new car to me that I bought with the no start engine. Only 42000 miles since last timing belt change . Here's what I found when I opened it up.
      Several bolts on water pump  housing were loose. Alternator lower bolt was broken. The tensioner pulley was completely  broken apart so I don't have any pictures of that . Water pump shaft was bent and water composed inoperative. That's why the coloring on the water pump pulley is shows discoloring from the Heat. Who knows what happened in terms of the sequence....
      Anyone ever see this on a Lexus? I've had 10 Lexus before, worked as a mechanic 30 years, and I've never seen this before.
    • By ffl3883
      Hello,
      I have a 1999 LX470, 140k miles. I noticed there is strange noise (sounds like servo motor or some kind of !Removed! sound). when I first turn the key to light up the dash also when I press brake several times. It also happens frequently during driving when I press brake pedal. Brake still functions. Here is a YouTube link. 1999 LX470 Noise Behind Dash
      you might need to put on headphone to hear the noise clearly in the YouTube video. Just wondering what the problem is . Any thoughts and gauidance are appreciated.
      Regards
      Felix
    • By godons
      The auto open and close feature of the driver side mirror no longer works. It is stuck in the open position.  It also continues to make a high pitched noise like it is trying to engage the cams but cannot. I was told I would have to get a replacement mirror and have it painted to match the green paint. Can this be fixed?
