jbrubaker Posted February 18, 2004 Posted February 18, 2004 This light comes on on the dash. Is this standard or does it indicate low fluid? I have an ES400, 1994 Thanks!
steviej Posted February 18, 2004 Posted February 18, 2004 I have an ES400, 1994 haven't seen one of those yet, but I know what you meant. Is it the (ABS) light or the BRAKE light? If it is the word "brake" lit then just add fluid and that should take care of it. Toyota/Lexus brake fluid level sensors are very sensitive and often trigger the light before the fluid is visually low in the reservoir. If it is the yellow (ABS) light, then get it checked out by a ceritifeid Lexus mechanic. It may be a sensor or it may be the ABS modulator valve. steviej
SKperformance Posted February 18, 2004 Posted February 18, 2004 I agree ,can you be a bit more specific? You need to go to someone with an expensive scan tool if it is an abs sensor.
jbrubaker Posted February 18, 2004 Author Posted February 18, 2004 IT is the ABS light. Will get it checked out. Didn't know if there was a secondary reservior like on my 85 Mercedes. Thanks!
