Tranny Shuttering
pacoson
I have a 94 SC-400 with 111k on it owned for 2 yrs
My tranny was shuttering slightly until my local garage used a additive??
It helped for about 3k mi Now the Shutter is back.
And It's getting worse!
What is the "Shutter"? and will a fluid flush solve the problem?
Thank-You for any help
hmmm... the trans shop probably just added a conditioner in the trans to soften up all of the seals in the trans and if that worked for 3000 miles then use it again like an oil change :lol: but eventualy your trans will probably go out meaning big big bucks.
Have your mechanic drop the pan and flush out the metal filter as well. Make sure he uses only Toyota T-IV if it's an SC4 or 98-up SC3, otherwise it's Dexron III. If the problem persists it's possible the converter is weak, it can happen in these cars.
