How often should one get their fuel injectors flushed on their ES (or is it even necessary at all)? I'm not sure exactly what gas the previous owner used before I bought it but I only use Sunoco Ultra 94 gasoline.
- Also, does anybody recommend using a "synthetic" fuel system cleaner such as Valvoline Syn Power ever so often? Opinions on both issues are appreciated, thanks!
:cheers:
use a good flush every 3 months or so, almost any $20 dollar one is good
get a motorvac done about 130 and makes the car run like new it cleans the system out perfectly
I throw a bottle of Chevron w/Techron (and yes, the synthetic formulation) in the tank with every oil change. That comes out to be about 3 per year.
It costs less than $10 USD at AutoZone.
steviej
I doubt that any cleaners are needed, especially when using Premium gas. On my fuel injected 92 Toyota pickup I havn't used any cleaners for 436,000 miles and the engine still runs like new. I did experienced a few hesitations from time to time and these were always solved by scrubbing clean the goo that gradually developes over time on the throttle body plate and bore.
sk,
What's this procedure, could you give more detail?
Thanks
