Hello, quick question, will flushing a trans. cause a trans to leak where the trans and motor mate? I have a 04 ES, 70000 miles, had fluid changed and flushed at about 60000 miles, leak didn't happen till about 9-10 months later. Had car since new. They used a B-G system to flush. Said it was low preasure, took a while to complete, watched them hook up run the system. No shifting problems. Leak fixed by dealer on warrenty. Thanks.
Tim
10 months later is a very long time to try and associate at leak with a trans flush. Many people would recommend avoiding a trans flush, just change the filter and oil at the recommended intervals and you should be fine.
You sure it was a transmission fluid leak or a rear main seal leak?
That said...tranny flushes are kind of a nono IMHO.
Definately trans fluid...
I would personally think its just a breakdown of the transmission gaskets more than the flush you had done.
Had it happened right after the flush I'd feel differently...
thanks for the info, no more flushing, next time just a fluid change. Dealer didn't do a great job with this, took them two times to get it right. The tech. tore the first gasket, leaked worse. No leaks now.
Tim
Every 15,000 drain and refill byself. Next 15,000 take it to mechanic for drop pan change filter and refill trans.
I maintained my 97 ES300 this way and until it was totaled at 362K, trans was running like New.
362K miles? Wow! Good job!!
