Vsc, Abs, Vsc Off Issue.....
okay a few months ago VSC, ABS, VSC OFF lights came on my 99 Lexus GS300...... I really didnt care about it since the car was functioning normal....but recently i saw a video on how VSC works and considering the way i drive...i really need that VSC to be working properly....also VSC works with ABS....so i checked out the ABS code and it says passenger side sensor...so yesterday i ordered a OEM ABS SPEED SENSOR.. total $187.00........ so im thinking if i replace the sensor that should turn off the the ABS along with the VSC light.. since the VSC works ABS ..according to the video i saw..... so im hoping the lights will go off.....
did it help when you bought the OEM ABS SPEED SENSOR did the 3 lights go off
The car has been totaled :o
yes unfortunately, and that darn company is having hard time giving me refund, its amazing how they quickly take your money......
Hey I have a question. When you encountered this issue was there beeping noise along with the abs, brake, and vsc lights being on. I'm having this issue but I can't figure this out. When it comes on my brakes fail (wont start). This morning I drove it failing then the lights cut off and everything was fine. Can you please help me. Redwar2477@yahoo.com!!!!!!!!!
Hello everyone, this is my first post.
I also own a 98 GS300 since November and I encountered that Issue 3 times already. Living In canada and getting pretty cold weather, one morning I got stuck in snow and gave a bit too much on the gas pedal. That was the first time these Lights came on, I also noticed that the VSC control really got off since I could drift in the road pretty easily. It reseted after I got the motor to off for a good time, couple of hours. Hapenned to me 2 others times, when I tried to accelerate really fast from a stop.
I went to the deal and talked with some mecanicians. One of them had already seen this problem 2 times he said. He says it's probably the abs pump in the main abs control computer (if I can say so) that is getting aged and tired. However this cannot just be changed, it requires the change the whole module, which is around 3000$ CAN.
To myself, this looks like a good explanation to my problem, would make sense since it happens when I ask a lot of power to the car. I hope this helped you, if however it happened in the same circomstance as I had. Sorry for my bad english.
Good Luck !
