Dashboard Brake Light Comes On
averona
Dashboard brake light comes on at weird times. A. when braking kind of hard. B. when accelerating (sometimes)??
Any ideas?
ADD FLUID TO THE BRAKE FLUID RESERVOIR IN THE ENGINE COMPARTMENT!
Exactly my sentiments but being a Brit I have to be polite :D
Any ideas?
GREETINGS FROM THE UNITED STATES!!....I SEE YOU HAVE GREAT TASTE IN CARS! HA HA HA! :cheers:
Any ideas?
definately low on Brake Fluid - if your fluid looks very dark brown or almost black in the master cylinder reservoir - you can use a turkey baster to pull some of the old out before putting in new. just be sure to twist the screen filter out first. just an option. fill your reservoir almost to the max line.
if it is low again in a couple weeks or months, you have a leak somewhere for sure.
good luck!
B)
