99lsguy Posted January 15, 2004 Share Posted January 15, 2004 Hey guys,, Just saw a add in CompUSA for a device that converts the 12V outlet to 90W electrical plug. I guess you can use it for Small TV, DVD, etc while on a trip. How does this effect Battery/Alternator/Elec System in the LS? Is it totally harmless to the vehicle? Thanks, 99 Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 15, 2004 Share Posted January 15, 2004 it doesn;t affect the car at all i have one powering my ps2 and it works fine but once the voltage drops below 13 vdc it may shut off as it is under powered when the engine is not running some cheap ones also create a hum in the fm radio stations when on Quote Link to comment Share on other sites More sharing options...
99lsguy Posted January 15, 2004 Author Share Posted January 15, 2004 sk, Thank you ! 99 Quote Link to comment Share on other sites More sharing options...
mjrav Posted January 15, 2004 Share Posted January 15, 2004 I had a similar thing years ago. That one required the engine to be reved up several thousand RPM in order to get useful voltage. It wasn't very practical. Quote Link to comment Share on other sites More sharing options...
mejojo Posted January 15, 2004 Share Posted January 15, 2004 They are call DC->AC power inverters. They are handy, but be sure it's enough power to do what you want. Also, be aware that the fan in the unit can be a little loud. I got a Jensen on eBay (brand new) for under $20 incl shipping. Same model sells at Best Buy for about $40. Check there for more output power for less money. Mine is 160W (peak 300W) and it's enough to power a portable DVD player easily, but it isn't enough to power a canister vacuum cleaner. (I had hopes of not having to string out an extension cord to clean the car.) I haven't tried much of anything else. Joe Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 16, 2004 Share Posted January 16, 2004 i guess it all depends on the car and what you are trying to charge the one i use i also used on laptops ,but i would not recommend using anyof them to recharge any kind of battery as it will destroy it mine was about 1 "thick 3" X 4" for overall size and it works great for the laptop or ps2 i never had to rev the engine as it remained on fine unless the car was turned off it also does not have a fan either only the larger ones do Quote Link to comment Share on other sites More sharing options...
99lsguy Posted January 16, 2004 Author Share Posted January 16, 2004 Thanks everyone! This one is on sale for $20 but is only 90W. They advertise it to fit in the cup holder. From the info I'll wait and pick up one with more "juice" when at a good price. 99 Quote Link to comment Share on other sites More sharing options...
tansupplyman Posted January 16, 2004 Share Posted January 16, 2004 Joe, you can buy a hand held vac that plugs in the lighter outlet--not sure where I got mine tho--use it at car shows(not Lexus) after parking. But probably at Pep Boys,etc Quote Link to comment Share on other sites More sharing options...
