John K Posted June 18, 2009 Share Posted June 18, 2009 I recently took my 2004 GX470 (75k miles) in for routine maintenance. The shop tells me there is a pink califlower running down the radiator, indicating a leak. They recommend replacing the radiator with an after-market unit for an out-the-door cost of $583. This shop is independent (toyota and lexus trained technicians, who formerly worked at Toyota and Lexus dealers). I stopped going to a distant dealer after my warranty expired. Have Lexus (or GX470s in particular) had radiator leak problems? I read one other forum for Lexus owners stating that some Canadian made radiators had manufacturing problems in the mid 2000s. Any experience out there with this? I am being soaked for $583? Quote Link to comment Share on other sites More sharing options...
lvivuk Posted June 20, 2009 Share Posted June 20, 2009 I recently took my 2004 GX470 (75k miles) in for routine maintenance. The shop tells me there is a pink califlower running down the radiator, indicating a leak. They recommend replacing the radiator with an after-market unit for an out-the-door cost of $583.This shop is independent (toyota and lexus trained technicians, who formerly worked at Toyota and Lexus dealers). I stopped going to a distant dealer after my warranty expired. Have Lexus (or GX470s in particular) had radiator leak problems? I read one other forum for Lexus owners stating that some Canadian made radiators had manufacturing problems in the mid 2000s. Any experience out there with this? I am being soaked for $583? My 04 had same radiator leak at 80k, replaced by dealer under warranty. As an example, GX radiator at AutoZone is $270-$300, eBay prices are $150-$250. Shops usually have their suppliers and get discounted prices. Replacing GX radiator is not that hard, there is plenty of clearance in the front. I would ask the shop how much the labor costs and go from there. Quote Link to comment Share on other sites More sharing options...
mann777 Posted June 21, 2009 Share Posted June 21, 2009 You just need basic tools to do the replacement, at your home garage. Simple save labour cost goto this website http://www.drivewire.com It only cost 275/- Quote Link to comment Share on other sites More sharing options...
KKIM124 Posted June 23, 2009 Share Posted June 23, 2009 Just took my 06 GX in for 45k service and they found a leak in the radiator and replaced it under warranty. Not sure if it a common problem but may be. Quote Link to comment Share on other sites More sharing options...
denslexusgx470 Posted June 25, 2009 Share Posted June 25, 2009 This is interesting. Never noticed that radiator leaks were starting to become common on the GX. Luckily I never had a radiator leak (knock on wood) and I'm at 54k miles at the moment. Quote Link to comment Share on other sites More sharing options...
megabrat1 Posted June 30, 2009 Share Posted June 30, 2009 i have a 2004, and i had to replace the rad as well. Mechanic said that the radiators on most models in the 2003-2006 range were poor in quality. He replaced it with an OEM Radiator for $350 + labor (150). Quote Link to comment Share on other sites More sharing options...
tw0leftskis Posted July 17, 2009 Share Posted July 17, 2009 On some GX the radiator will develop a leak(slow leak) on the left lower corner of the radiator. It will have a crusty pink flake build up in the area. I recommend getting a factory radiator, because the radiator hose will have a snug fit on the snout using the original hose clamps. Quote Link to comment Share on other sites More sharing options...
eijitoyoda Posted July 22, 2009 Share Posted July 22, 2009 My radiator leaked at 49k miles. I am very glad I purchased an aftermarket extended warranty. It almost paid for itself after the $800 the Lexus dealership charged to do the repair. Quote Link to comment Share on other sites More sharing options...
mann777 Posted July 23, 2009 Share Posted July 23, 2009 I think manufacturing defects are very rare, unless anything associated with welding occasionally seen as most notably, failures occur where oil residues are present within radiators if not lexus would have issued a TSB under the comprehensive warranty for such model. My 04 is still kicking perfect( touchwood) I think Premature failure will usually occur due to pitting corrosion although this will have a wide range of causes. Commonly, oxygen pitting, chloride induced pitting and pitting associated with copper plating are found. Pitting usually occurs at areas of natural stress, i.e. convex folds or near welds which are anodic sites in the radiator. Manufacturing defects are rare but where found are commonly associated with welding defects. New radiators fitted to old systems are anodic to the system and are prone to premature failure. Old radiators may eventually fail due to under deposit corrosion associated with sludge deposits, usually magnetite, at the bottom-centre of the panel, which causes pitting corrosion in the absence of any specific fault with the water or system. In most radiators sludge accumulation causes blockage, or inefficiency, long before the radiator leaks. Quote Link to comment Share on other sites More sharing options...
