Paint Code?
bear
Was wondering if anyone knew where to locate paint code....or more specifically, if anyone had the paint code for two-tone silver lexus. Need upper silver paint code, as well as lower (darker) silver code. It is for a 1990 ls. I tried the manual to no avail. thanks.
some codes from a may 19th post.
Note that these are on the driver's door post just above the latch. there will be 2 lines--top is upper color code and lower is lower code.
Color Name - Paint Code - Year
Black Onyx - 202 - 2001, 2002, 2003
Graphite Grey Pearl - 1C6 - 2001, 2002, 2003
Crystal White - 062 - 2002, 2003
Diamond White Pearl - 051 - 2001
Millenium Silver Metallic - 1C0 - 2001, 2002, 2003
Intensa Blue - 8N8 - 2002, 2003
Spectra Blue Mica - 8M6 - 2001
Solar Yellow - 576 - 2001, 2002, 2003
Electric Green Mica - 6R4 - 2002, 2003
Dark Green - 6Q7 - 2001
Absolutely Red - 3P0 - 2002, 2003
Spectra Mica blue 8m6
silver 1c0
1999 Diamond Pearl 051
2002 Crystal White 062
1998 Black Onyx 202
2001 Model Colors
051 - Diamond White Pearl
6Q7 - Imperial Jade Mica
8M6 - Spectra Blue Mica
202 - Black Onyx
1C6 - Graphite Gray Pearl
576 - Solar Yellow
1C0 - Millenium Silver Metallic
3N3 - Auburn Sky Pearl
2002 & 2003 Model Colors
062 - Crystal White
202 - Black Onyx
3P0 - Absolutely Red
576 - Solar Yellow
585 - Cibola Gold Metallic
6R4 - Electric Green
8N8 - Intensa Blue Pearl
1D2 for new thundercloud metallic is300 special design 2003?
2003
XXXX 062-Crystal White
XXXX 1C0-Millenium Silver
XXXX 202-Black Onyx
XXXX 066-Parchment Crystal
XXXX 3P2-Black Cherry Pearl
XXXX 4P7-Mystic Gold Metallic
XXXX 6S5-Mystic Sea Opalescent
XXXX 8P9-Blue Marlin Pearl
XXXX 8P8-Blue Onyx Pearl
2002
XXXX 202-Black Onyx
XXXX 3N1-Cinnabar Pearl
XXXX 4P2-Burnished Gold
XXXX 6S5-Mystic Sea
XXXX 6S6-Midnight Pine
XXXX 8P8-Blue Onyx
XXXX 1C6-Graphite Gray
2001
XXXX 062-White Crystal
XXXX 202-Black Onyx
XXXX 8P8-Dark Blue P
XXXX 4P2-Beige M
XXXX 3P2-Bordeaux Mica
XXXX 3N1-Red
XXXX 6S6-Dark Green
XXXX 1C0-Silver M
2000
XXXX 202-Black Onyx
XXXX 3N1-Red
XXXX 4P1-Copper Brown
XXXX 4P2-Beige
XXXX 6Q7-Green
1999
XXXX 051-Diamond White Pearl
XXXX 199-Alpine Silver
XXXX 202-Black Onyx
XXXX 3N1-Cinnabar
XXXX 4P1-Burnished Gold
XXXX 6Q7-Dark Green
XXXX 8M6-Spectra Blue
XXXX 4P2-Copper Brown P.
1998
XXXX 4P1-Antique Bronze
XXXX 202-Black Onyx
XXXX 3N1-Cinnabar
XXXX 6Q7-Imperial Jade
it doesnt really matter since you have to go to the dealer and get that paint and you will just give the guy your vin number and he will give you correct paints.
THANKS Tansupplyman!!!!!!!!!!!!!! There is a company......towerpaint.com that will mix the factory color into an aerosol can. The spot I have to do is on the lower front bumper. A light sanding and adhesion promoter (also from towerpaint) will do the trick. I did this on my mercedes 300e and it looked great. A buddy of mine took his (Merc) to the dealer, and you can clearly see the "new" paint as they had trouble matching (as they used computerized matching). thanks again.
  • 2 months later...
:angry: What is going on with peeling paint on two spots on nose of sc430 2003? Has anyone else had this promlem? Looks like could be the clear top coat? First spot that happened dealer tried to say hit a rock even though no dent... today hand washing car, went to rinse, the nose and more paint started to peel.
